Results 1 to 15 of 20
Thread: Loosen valves on a Honda?
    Nov 2011
    East Greenville, Pennsylvania
    465
    Has anyone ever heard of loosening the valves on a Honda 4 stroke because it runs better? Sounds crazy to me
    1985 Kawasaki Tecate 250 with kx 500cc motor
    1985 Honda ATC 70 custom built with lifan 125cc
    1985 Honda ATC 70 custom powder coat slight mods
    1985 Honda 250sx
    Yamaha zinger 90cc 2 stroke
    1985 Honda 250sx custom green and black build
    1985 Honda 200x
    There is a certain amount of lash they should have. Check the service manual for the respective machine. That's how they'll run best.
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    It will only run better if they were too tight. Its pretty ssimple to set them, they could alsoo be too loose. Lots of times if your valve adjustment is out of whack you will notice a big difeerence in how easier it starts after setting them.youu should get a manual and give it a try, its a good part of routine maintenance to set them. Especially on a honda, after you do it a few times it shouldn't take you long. All you do is undo the timing plug oon the crankcase above the flywheel, line it up with TDC, unscrew the timing covers, and set the lash with the jam nut and setscrew. You will need a Manual for the settings, it will explain how to do it aswell. If you've never done it, give it a try, there's no way it will make it run worse.
    texas
    567
    actually, you can make it run worse if you have trouble finding TDC like i did with my 350x that has an F and I. not sure why. as long as you get it on tdc youll be good though. ive heard of guys adjusting valves while an engine is running on a car. WITHOUT using feeler guages! strictly by sound. i wouldnt trust it.
    Quote Originally Posted by twitch101 View Post
    That's actually not unheard of for cars. I've seen people do it with small block Chevys. If you know what you're doing it works just fine, on cars that is. I wouldn't do it on a trike.
    Texas
    137
    I've done that myself, on the 350 (hydraulic lifters) in my '72 Chevelle. Removed the valve covers, put clips over the pushrod ends of the rocker arms (to keep oil from spraying everywhere), started the engine and let it warm up, then backed off the pivot stud nut of each rocker arm (one at a time) until the clearance opened up between the valve tip and the end of the rocker arm and it started "clicking", then tightened the nut until it just stopped.
    Can't do that on a trike, the adjuster is on the end of the rocker arm and would be moving up and down rapidly while the engine is running.
    TRX 70 - rescued from the trash
    84 125m - first restoration
    84 200m - now a four wheeler with 450r suspension
    84 200x - restored, now my rider
    83 250r - current project
    Looking for an FL350 (Odyssey)
    Nov 2011
    465
    Hmm thanks. I just picked up a 250sx. 1985. Starts up first kick even cold. Everything works great. Drive 7 hours which sucked. I want to do the gear oil in the rear. Motor oil and adjust the valves. This will be the first 4 stroke I've ever worked on.
    1985 Honda 250sx
    1985 Honda 200x
    NEPA
    7,051
    Quote Originally Posted by jmax857 View Post
    This post is basically right,,,FOLLOWING THE MANUAL..However !!,,You can MAJORLY mess things up adjusting valves. Too tight, you will kill your rocker arms and camshaft. You can break valve tips. Also with loose valves,,the extra lash is hard on the valve tip,,and can break them. Especially on 350X exhaust valves. Seen that way too many times. You want your valves adjusted where they are supposed to be.
    Dec 2002
    Orange County, NY
    1,772
    Usually if they're too tight (and no one has been monkeying around in there) its because the valve seat is starting to get pounded down allowing the valve to move further "up" and therefore the lash becomes too tight. I've seen it before and you can loosen the valves but if it keeps happening you're gonna need a valve job.
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Nov 2011
    465
    Ok thanks. It runs great but I would clean the carb cuz it Boggs at wot
    1985 Honda 250sx
    1985 Honda 200x
    Nov 2011
    465
    New plug and fuel lines an fuel filter and it runs great. Air filter is next on my list. But my Tecate comes first cuz it's almost done
    1985 Honda 250sx
    1985 Honda 200x
    Nov 2011
    465
    How do I find tdc an be sure it's tdc on my bike. I want to adjust the valves but its my first time. The bike starts first kick even cold. I don't want to screw this up
    1985 Honda 250sx
    1985 Honda 200x
    Jan 2011
    mifflinburg
    525
    if it starts first kik in cold, the valves seem just fine. I wouldn't touch them.
    Nov 2011
    465
    Ok good. Thought so but I like to do everything myself to make sure it's good. I want to dig into the carb and give it a thorough cleaning
    1985 Honda 250sx
    1985 Honda 200x
    jmax857's Avatar
    bancroft canada
    354
    Get a manual, it will save your life.
