Thread: Shifter and shift shaft can spin 360 degrees... stuck in third
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    Got new rings on her after siting for 2 months. new paintjob, got her all together starts up. ridding her around and BOOM. i go to down shift from 3rd and the shifter is vertical...
    Shifter shaft just spins and dose nothing. any thoughts? no clicking or bad noises, but it looks like im going to have to split the case for the 4th time.
    Unit is a 1985 Tri-moto 225DX three wheeler with a 5 speed auto clutch.
    Pictures of the issue.
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Feb 2006
    EC
    1,607
    You might want to download a manual fromhere, that will help. try removing the right side case cover, the shaft runs al the way through, &(on the 125 & 175) you'll be able to see what's going on there. Good luck.
    Feb 2006
    EC
    1,607
    Ooop, hit "enter I was done- the 175 & 125s have the whole clutch & shifting mechanism right there on the right side. I've got no experience w/ the 225s, but how much different can it be, right?. It might just be an easy fix.
    Jan 2011
    Avon, Minnesota
    641
    not being a picky person but if u say u only have 4 gears there should be 5
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    ^ well, he said this would be the fourth time splitting the cases so maybe he forgot a gear
    Yank off the right cover, you'll find the end of that shift shaft in relation to the drum having come apart in some way......
    Some motors, the clutch has to come off to see all the shifting goodies.
    Aug 2011
    Richmond NH
    336
    Quote Originally Posted by the great gazoo View Post
    Got a manual, didn't think it would answer my question. going to remove the side cover tommorow.
    Quote Originally Posted by yamaha driver View Post
    was tired, it is indeed a 5.
    EDIT: Shift shaft broke at the factory wields. had a spare. fixed.
