Thread: rim swap
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    rim swap
    ok guys i am trying to put a big red rim on the front of my SX and it seems it is too wide. the 8" rim that was on the front, the valve stem is bad so I thought I would put the spare big red rim we have which is a 9" rim on the front of my SX. it appears its too wide. has anyone ever done this swap before? if so how did you do it? i cannot get the hub and tire and rim assy to go between the forks. help!
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    NEPA
    7,051
    Oddly enough,no, A 25/12/9 tire will not go where a 22/11/8 goes. It won't work.
    397
    wow that sucks. so the bigred rims will work on the rear but not on the front? thats odd. guess i will have to get another valve stem
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Beaver Falls, PA
    2,666
    I just learned that a Big Red front axle is quite a bit longer than an sx... like 2-3 inches longer. I didn't measure but would I assume the hub is wider as well.
    Mar 2011
    St. Paul, MN
    74
    yea the sx front forks are narrower than the Big Reds, so you can't use swap front tires. Of course you can put any size wheels on the rears, just need the 4/110 bolt patterns and an offset that works with your set-up. i.e. 2-5, 3-5, 2-6, 3-6 etc. We just put some older 25/12/9 Bearclaws on the rear of an 250sx we just picked up. Those wheels were on a BR, but we all upgraded to 26's and 27's so the 25's were just sitting around.
    My wheelers:
    current:
    '86 Honda ATC Big Red 250es - disc brakes, lifted, spaced and 27" Super Swamper TSL / Vampire (1.22" lugs) all-around
    '86 Honda ATC 250sx - Mud Bugs (1.19" lugs) in the rear
    '85 Honda ATC 250sx - not currently running
    '85 Honda ATC Big Red 250es - runs
    previous:
    '85 Honda ATC 200s
    397
    I need to get some 22" tall tires for the rear. the 25" tall tires on the rear and the 22" tall tire on the front makes the turning real touchy. i had a tube put in the front tire today because it is kinda dry rotted and i dont like airing it up everyday so i had the tire shop put a tube in it
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
