Results 1 to 13 of 13
Thread: ESR 350r build..
    Blossvale NY
    4,563
    ESR 350r build..
    Hello new members! At the request of my brother in law who is a new member here, I'm going to post some pics here of my ESR 350r build. Not fishing for compliments, just thought I'd give our new members a chance to comment. All comments welcome, positive or otherwise. Also, feel free to ask any questions you have.
    Hope you like... Joe
    First 2 pics are of my R the way it used to be... Stock cylinder bored .060, ESR 38mm Airstryker carb, 1Dir Racing reedblock and torque spacer, high comp head gasket, FMF Fatty with silencer, Hinson basket and pressure plate, ESR billet counterbalancer carrier and all bearings and seals in bottom end/transmission replaced. Chassis wise, nothing real spectacular, Durablue +4 axle, LSR double bearing carrier, all Maier OEM style plastic.
    Second 2 pics shows the chassis waiting to be cleaned up while I put the 350 together..
    Last pic shows my goodies...
ID:	139085   Click image for larger version.
ID:	139086   Click image for larger version.
ID:	139087   Click image for larger version.
ID:	139088   Click image for larger version.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    more pics
    Just pics of the assembly stages. I decided to go with the semi-'85 engine color scheme. Painted the cylinder and crankcases by hand myself.. 4 coats on the cyl, 3 on the cases...
ID:	139092   Click image for larger version.
ID:	139093   Click image for larger version.
ID:	139094   Click image for larger version.
ID:	139095   Click image for larger version.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    Oddly enough, in all the excitement, I forgot to take a pic when it was all back together and ready to fire up!
ID:	139097   Click image for larger version.
ID:	139098   Click image for larger version.
ID:	139099   Click image for larger version.
ID:	139100   Click image for larger version.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    And it starts!
    So, in the end, it now has an ESR 350 BB kit with custom TRX9 porting, ESR ATC5 pipe with silencer, ESR reedblock, newly rebuilt crank with old-school Wiseco rod. I stayed with the short rod setup as there is DEFINITELY a spark plug cap clearance issue due to the ESR head having the sparkplug hole straight up as opposed to angled slightly like the stock head. Running the cylinder spacer plate required with the long-rod topend would only worsen that little problem...
    Here is a vid of the first start-up. Lemme tell ya, sounds completely different and ALOT meaner!!!
    http://www.youtube.com/watch?v=30siE...Q-fzSN5y26wTKo
    SO, what do you all think??
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Nov 2011
    Schenectady ny
    48
    Very nice build bro!! What were you running before the 350? I have not been a big fan of the big bores, I have a LRD 265 that I ride on the ice and I have not seen a 310 0r 330 that has impressed me enough to step up in cc. Let me know what you think of it, im sure it will be bad a55 either way!
    Blossvale NY
    4,563
    Just realized I have a bad case of brain flatulence and posted this in the open forum. I'll PM a mod and see if they could kindly post this in "New Member Discussion"..... Did ya hear that??? Yeah, that was the sound of me slapping my forehead! LOL!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    Quote Originally Posted by dubber97 View Post
    Thanks. Unfortunately I probably won't get to ride it, jet in and break it in till spring. I have snow here in NY now and snowy slippery conditions aren't the best conditions to break this thing in...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    861
    I can post up some pic of my 330 with the plug in and boot on its no to bad to change the plug. Awhile ago I thought I read people saying the 85 frame is slightly different. Looks nice.
    ]1986 ATC 330R
    Blossvale NY
    4,563
    Quote Originally Posted by pantera1975 View Post
    Yes, I wasn't able to get the OEM plug cap on without pretty much ruining it. I'm going to look for a short 90deg cap. If that doesn't work then I'll be getting some of those BR8ECM shorty plugs...
    I would definitely be interested in a pic of your '86 in that area above the head with the plug in....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    rjs89ia's Avatar
    rjs89ia is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Kingman, AZ
    271
    on my 85 long rod 310 i have a little clearance issue but still run the stock plug cap it doesnt snap on there all the way but i havent had any issues with it. im gonna try swappin to a ngk 90 plug cap tho so it does snap all the way. there are differences between to 85 and 86 frames too. the 85 has a gusset to the bottom side of the support pipe close to the sparkplug and the lower tank mounts are like a piece of pipe cut in half and welded on with capped threaded ends. the 86 has a support pipe welded in with no gussets and the lower tank mount is what looks to be a piece of 7/16 bar stock with machined in threads. kinda hard to paint a picture with words here but if you saw each bike next to one another you would understand it. im just lucky to have both so i can reference each.
    861
    Heres my plug set up it fits on my 86 with no problems the NGK boot # is TBO5EM I cant remember which digit is the cap color but you can get black and I think blue.
ID:	139116   Click image for larger version.
    ]1986 ATC 330R
    Blossvale NY
    4,563
    Yeah, it certainly looks like you have a little more room than I do...
    On mine, that gusset that rjs89ia mentioned makes it just a little bit tighter..... It's hard to see in the pic, but the plug cap is right against that brace. And the cap you see is all that left of the OEM cap! LOL! I will be suprised if I'm not able to find a different style or smaller cap that will work. I just need a smidge more room.
ID:	139119   Click image for larger version.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    Oh, and my previous setup was a stock cylinder bored .060, ESR 38mm Airstryker, 1Dir Racing reedblock with torque spacer, high comp head gasket, FMF Fatty pipe and Powercore silencer. Bottom end had all bearings (including transmission) replaced except for lower rod bearing. Hinson clutch basket and pressure plate, ESR billet counterbalancer carrier with balancer bearings, Ricky Stator regulator and stator....
    It ran pretty darn respectable. I used to drag my cousin on his lowered, geared, cammed, piped and rev boxxed 450r. He would only beat me on the holeshot because I had such a hard time keeping the front end on the ground, or close to it. Bean bag on the fuel cap and it would still hook and fly up on me. But once I got into 3rd gear he wouldn't pull any farther in front of me..but I couldn't close on him either.. Hopin for some different results next season. I'm sure the holeshot will still be problematic racing against that slammed 450, but I'm hoping to have enough 4th, 5th and 6th gear hp to run him down...
    Next project: +4 swingarm... Probably next winter though... outta wheeler money for now. But. I'm still happy I was able to pull this off!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
