Results 1 to 15 of 18
Thread: 350x starting problem
    ustin666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    moncton
    237
    i was doing a wheelie on the 5 gear and when i broth it back down my trike staled and i could not start it again i change my spark plug cleaned my carb but it still wont start. it sounds like its going to start but it dos knot start. need help
    Camano Island, WA
    361
    Make sure you have spark. Pull the plug out, put it in the boot, and then set it against the cylinder. Turn the engine over and watch for sparks to go across the gap. Does it still shift through the gears? More info helps. As much as you know.
    Dec 2009
    moncton
    237
    yes all works there is spark, engine turns great all gears work. engine sounds like its going to start some times butt do not. i was tinking the timing chain could have skip put i did not hear any noise it just staled.
    NEPA
    7,051
    Check compression,,and you are more than likely right that you jumped time. Was it rattling before ? If so,,it could have. But go back to the basics. You have spark,fresh fuel? Then you need compression,,IN TIME. Check compression,valve timing and adjustments.
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    How long were you doing the wheelie for?
    Check to make sure your carb float isn't stuck in the upright position ( this exact thing happened to me once)
    I would check your compression, if its good, go for timing .
    Unless you had one noisy/sloppy 350X motor, I can't see it jumping time. I can see a fuel issue though which is a simple check........
    Define "cleaned my carb".
    Dec 2009
    moncton
    237
    the first ting i did was cleaned my carb. it could be my timing chain because my chain was doing a little bit of noise. if my chain would have skip it would have did some sort of noise right ? i did not hear anything when it staled. i did knot do a compression test yet put it still kicks hard and i rebuilt my engine last year so it shouldn't be my compression.
    Mar 2008
    EastGreenbush, newyork
    3,494
    first thing i always do on anything that wont start is make sure the fuel is ok, open the float bowl drain screw, and let the fuel flow through the carb for a minute. if you do that, know you have a nice fat spark, and ass enough to kick it, then its something else!
    Jan 2011
    Greene,Ia
    688
    something doesnt sound right where you heard timing chain slapping/noise, when it was just rebuilt last year....
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    NEPA
    7,051
    Quote Originally Posted by ustin666 View Post
    If you heard noise before. The landing from a wheelie that fast could very easily have jumped time. That throws your compression " off". I m not referring to worn valves or rings. If you properly CLEANED your carb and everything is right. New spark plug,and it doesn't run,It's a mechanical issue,my guess being timing from your description. Let us know what you find please!
    Quote Originally Posted by SteveCZ28 View Post
    Everyone seems to have a different idea of "rebuilt"...........
    Dec 2009
    moncton
    237
    im going to check my timing chain. and i was going to change my chain ofter i am done my new engine.
    Dec 2009
    moncton
    237
    i did my compression test and it was 140psi that knot good. but is -6 outside and you should do your compression test when engine is hot.
    Dec 2009
    moncton
    237
    i checked my timing and it was good but my timing chain was stretched so i removed it and i am going to buy a new one.
    Dec 2009
    moncton
    237
    should i buy a Honda chain for 120$ or a aftermarket one if there's any?
