Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: failed por 15 tank sealer removal
    Mar 2011
    St. Paul, MN
    74
    I used the POR-15 tank sealer recently. It worked great. I used MEK solvent, BBs and nuts & bolts to remove old dirt, rust and some old pealing sealer. I just shook it vigorously for a very long time...though it woulda been nice to strap it to paint shaker! then I used a magnet to get out the BBs and nuts after shaking.
    As far as drying goes, I set an old hair dryer in the tank for hours, adjusting the position several times...it needs to be completely dry! this is the most important step!
    I agree that you could leave the old sealer in the tank if it is stuck.
    My wheelers:
    current:
    '86 Honda ATC Big Red 250es - disc brakes, lifted, spaced and 27" Super Swamper TSL / Vampire (1.22" lugs) all-around
    '86 Honda ATC 250sx - Mud Bugs (1.19" lugs) in the rear
    '85 Honda ATC 250sx - not currently running
    '85 Honda ATC Big Red 250es - runs
    previous:
    '85 Honda ATC 200s
    na
    5,702
    Quote Originally Posted by jeswinehart View Post
    I would not spend too much time on removing what is stuck in place but rather just re-coat it again with same product (which i have only heard high praise for) or use the RedCoat (which is all I have ever used after 1 terrible exsperiance with that crap (can not think of the name of it right now darn it!) CREAM, that stuff and I did not get along at all.
    But anyway, simply recoat it IMO
    john
    You have to be about the 20th person I have heard complaints from using the "Kreem" kits.
    I had a street bike tank with a hole behind the mount bracket. Big enough of a hole that gas or water would just stream out of it. I used the Kreem kit on it, the "whole kit" after 3 days of washing and drying the tank. Then I let that stuff sit outside on my trailer in the tank, and had the wife rotate the tank every 1 hour for 2 days in the middle of the hot June Sun. They tell you you will have extra to dump out..I never did.
    I have run over 15 tanks of fuel through there and rode that bike for a year and 1/2 with no issues and over 2k miles. I must have got lucky, cuz all I hear is horror stories about Kreem anymore.
    Proudly NOT a member of
    "Team on the Teat"
    Jan 2011
    Kearney Nebraska
    32
    I have used POR 15 on many fuel tanks. On my 110 and on a JD model A tractor and on my 38 D2 Cat pony engine tank. I have had great success with it. It's all in the prepping before using.
    I wash the tank with straight (not watered down) muratic acid and I will through old bolts or nuts even rocks into the tank. Shake the living heck out of then drain and flush. The Cat diesel tank I had to wash at least 10 times. Looked like a new tank when done.
    Use caution with muratic acid.
    Quote Originally Posted by studebakerjim View Post
    Extreme caution! Very dangerous stuff!!!
    3wheely's Avatar
    3wheely is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Florida
    259
    I just used por-15 and it worked great! The tank has to be completely dry or you're just wasting time and money. I used a shop vac and sucked every drop of water i could get out of it, then used a hairdryer for at least two hours. Then let it sit for another day just to ensure it was dry. After rolling the tank make sure you get any access out or it will puddle and cause problems. I then let the sealer dry for 5 days. Very happy with this product.
    Dec 2002
    deer park, texas
    2,336
    I use por15 for everything and it has always worked perfect except in ATC 70 tanks. I dont know if it has anything to do with the size, material or what. But my fix is a couple handfulls of small nuts, beat it around then reapply. It always sticks the second time.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Dec 2002
    salem, nh
    1,339
    instead of letting a tank sit for a few days after rinsing with water you should fill it completely with acetone at least twice and shake it around. as soon as you dump the water out flash rust occurs, and letting a tank sit for days after using water you're not helping the situation. acetone + compressed air/hair dryer whatever and then kote it
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    zeeker1's Avatar
    zeeker1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canton Ohio
    184
    I have used a POR15 tank sealer kit with excellent results. I followed every direction exactly. I read about a guy who packed his tank in a heavy box packed with bubble wrap (tank filled with a couple of handfuls of screws) and put it in his clothes drier for a few hours. I've never personally tried this but the idea sounded good to me. Also seen a video of a guy who strapped his tank to the rear wheel of his jacked up lawn tractor and let it run all afternoon.
    Oct 2007
    Minneapolis mn
    4,067
    YOU CANNOT REAPPLY A POR15 tank sealer, on top of old tank sealer... I know this from experience. IT WILL NOT STICK TO ITSELF. I would try heating the outside of the tank with a propane torch, nice and easy... Otherwise, you may be screwed. POR says there isnt a chemical to remove it once its cured... (called and asked)
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    155
    I`ve used por-15 on a few old dirt bike tanks as well with good results. In fact the tank on my 200 has it in. Was leaking in the back where it bolts to the frame so the po gobbed silicone all over the outside and it wasn`t cuttin it. Been fine for some time now.
    NEPA
    7,051
    Quote Originally Posted by Thorpe View Post
    Well,shucks.. After thinking about this over night. I thought Exactly what Jeswhinehart said earlier.. Use whatever you could manipulate in there,,,remove all the loose stuff you possibly can,,then simply recoat it.. At this point,,not sure what else you could do. But Thorpe has Obviously been there don that! So,that's out.. Like Mosh,,I have used Kreem MANY times with perfect results,,I've heard lately that Ethanol eats it. And I would believe that in a second! Anyhow,,Just not sure what to tell ya on this original problem! Do it once do it right.. And like mentioned above,,the longer it sits,the longer it has to flash rust....
    texas
    567
    well the aircraft remover has certainly loosened it. i threw some tek screws in there and started shaking it around and i can see it doing some work. theres some stuff in there i just cant see or get to. ive contemplated having it cut open and cleaned/sealed but i dont think it would be worth it? for that money i could go with a plastic tank but plastic just doesnt look as good as the metal tanks. obviously something has to touch this por 15 chemically because por 15 sells a strip compound for it. . like others have said i like the idea throwing in in a dryer or paint shaker but i dont have access to that. maybe ill stop in harbor freight and pick up a cheap drill and leave it running while im at work with the tank attatched somehow.....this is the redneck in me lol
    is there an adapter someone makes for sandblasters to shoot in there?
    anyone have one of these?
    http://www.youtube.com/watch?NR=1&fe...&v=O1wnZpfT7bs
    texas
    567
    well its official, the answer to removing a por 15 sealer is this viscious and very volatile mix of methlyene chloride, and a little bit of MEK. it practically poured out of the petcock tube, let it soak for a few days though! time for round 2. im going to keep it drying for atleast a whole day before i seal it and ill keep it inside. i was on the verge of going for a plastic tank.
    Vernon Wisconsin
    188
    Sweet, good to know. Dont huff that mix it will give you the munchies.
    '79 Honda Odyssey
    '81 Kawasaki KLT 200 (highlighter)
    '85 Yamaha Tri-Z
    '82 Suzuki GS450L
    '05 Suzuki Eiger 400
