Could I heat and straighten an exhust muffler?
What type of of heat paint would be best.
Thanks
Thanks
to straighten it, im not sure. but with paint, i would go with automotive header/exhaust ceramic coating. its like spray paint, but made for high heat and exhaust parts
1986 Honda ATC200X
2005 Yamaha Road Star 1700
ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
Thanks man,
I bought this 350 x like 7 years ago from a guy and just rode it to death.
Now starting to clean it up and do some parts here and there.
Major project with the bearing carrier.
Its been sitting for 4 years 3 kicks and started cleaned carb, air filter removed mouse house and so on.
im actually takin the carrier apart this weekend on my 200x. when you rock it side to side, the swingarm moves alittle but the axle stays in place. not sure how bad the inside is, but im hopin i just need to replace the bearings and seals. if i have to replace the whole carrier i think ill go to RAD Mfg. and get the aluminum race carrier for $300
1986 Honda ATC200X
VHT paint is easiest to find, but not as good (when/if exposed to the elements) as ceramic. the paint will wear faster than the ceramic, but is alot easier to use and usually cheaper. just depends on how hard and where your gonna ride
P.S. usin ceramic is almost like wrappin the pipes with fiberglass wrap, like the oldskool bobbers have
1986 Honda ATC200X
I have a hard time finding ceramic do you know where i could look online?
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
2002 blaster sorry lol
Duplicolor hi-temp works great for me. It's available in TX USA at both Advance Auto Parts amnd O'Reilly Auto Parts. Significantly cheaper at O'Reilly.
I've also recently used VHT and RustOLeum hi temp but I like the duplicolor much better. Better flow. Better chemical resistance. Doesn't burn off as easily.
Hi Rodeo,
I just talked to Kirk at RAD Mfd. he had great tech advice on which carrier to go with if you order a carrier call and talk to kirk and he can steer you in the right direction. Good luck man
