Are these the right forks?There form a 1997 CR 125 according to the auction I bought them from. I was someday gona get Jason Halls kit to do this. What forks are others using on here for there projects.
]1986 ATC 330R
Everyones got different opinions but I like the KTM85SX 105SX front forks because they dont need to be shortened any.
Yeah they cost more up front but jason said them or the cr ones. I got these with the caliaper and rotor for $100.
]1986 ATC 330R
yes those can be used but as Billy said, they need to be shortened like 2 inches.
as far as i know Race Tech Suspension will shorten them for u.
TPC TRIKES
FSU Powersports
RNS Powdercoating
couldn't he slide the forks up a bit and run a shorter tire and not shorten them
The tire I run is 1.5 inches shorter than stock its a itp quad cross 22x7x10
]1986 ATC 330R
oh i wasnt thinking about travel
The inverted forks have a tapered section where the triple mounts. U can't just slide it to any position.
TPC TRIKES
FSU Powersports
RNS Powdercoating
^ Certain years and models you have a bit to play with.
None of the newer models can be moved much.....
I guess they tapered them to save weight, but it didn't help us much : /
