Has anyone straightened a bent exhust pipe?
on a 2 stroke no i havent... 4 stroke... eh you can try to but be careful of breaking or cracking it.... also i have seen people fix dented expansion chambers by closing off one end and filling the pipe with water and putting it in the freezer
1985 Kawasaki Tecate 250 with kx 500cc motor
1985 Honda ATC 70 custom built with lifan 125cc
1985 Honda ATC 70 custom powder coat slight mods
1985 Honda 250sx
Yamaha zinger 90cc 2 stroke
1985 Honda 250sx custom green and black build
1985 Honda 200x
You may be able to put it in a press and take your time and straighten it back out.
it depends where the bend is and how bad it is. can you post a picture of it?
1986 Honda ATC200X
2005 Yamaha Road Star 1700
ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
think it would work using water in the freezer to pop a big dent out of a gas tank? or is that just a stupid idea, might be worth a try as i am not gonna use it anyways with the dent in it
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
2002 blaster sorry lol
the whole left side of my tank is dented in, have no idea how it got there. it doesnt affect anythin but the look. i think we should still try it though! see whose gets fixed firsthaha
1986 Honda ATC200X
I have mine in thr freezer right now lol
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
Haha Ive never done a tank but I have done countless expansion pipes. Let me know how it goes with the tank!! You may have to do it a few times due to the fact water will only expand a certain amount when frozen... Also what about your breather on the cap?? Hmmm let me know!!!!
1985 Honda 250sx
1985 Honda 200x
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
So i had the tank in the freezer overnight just checked still not frozen solid! also i'm thinking i should have filled it up completely to add more pressure so i might have to do it again, i left it with a little room at top so i didn't get to much pressure and split the seams or anything but i might have left to much so if it doesn't do the trick then i am gonna thaw and go for totally full....In theory this should work!!!
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
Tanks dent, big knee dent? Easy fix... Long reach padded vise grips, (Irwin # 24SP) Empty tank, bolted to the frame of the trike, tape the swivel pads with a few layers of masking tape, (to prevent scratches) reach the clamp down through the filler neck, clamp on the dent, (centered) one pad inside the tank, other one outside, and pull on the outside of the vise grips... Pop out the dent. 10 minutes later, its good as new...
thorpes idea is probebly better lol thanks thorpe if the water doesn't work i'll be doing what you said
Trikes
83' atc 110
83' atc 200e
84' atc 200m
84' atc 200x
85' atc 200x
86' P3
Non ATC
