also im pretty sure you would want to raise compression to increase power depepnding on your set up... i know as far as a naturally aspirated motor works... if you have a 2.2l motor and you slap some 2.0 or 1.8 heads on there you will raise compression and iin turn generate more power with the right supporting mods... you will lose power if you go the other way... unless you are turbo than its a hole nother animal... but if you want to do anything i agree that those motor are not interchangable and you will need a special big bore kit for your 110cc motor... good luck with it all
1985 Kawasaki Tecate 250 with kx 500cc motor
1985 Honda ATC 70 custom built with lifan 125cc
1985 Honda ATC 70 custom powder coat slight mods
1985 Honda 250sx
Yamaha zinger 90cc 2 stroke
1985 Honda 250sx custom green and black build
1985 Honda 200x
