Results 1 to 10 of 10
Thread: Long Brake Line?
    rodeofan5656's Avatar
    rodeofan5656 is offline Girlfriend wishes I'd last longer than 8 seconds Arm chair racerAt the back of the pack
    Dec 2011
    Park City, KS
    389
    Long Brake Line?
    i need brakes on my 1986 200x. i know the rear caliper is the same as the front cal on a CR85. is there a long brake line/hose that i could run from a hand lever to the caliper in the rear? i just cant afford to get all the OEM brake parts
    1986 Honda ATC200X
    2005 Yamaha Road Star 1700
    ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
    Aug 2009
    Chesterfield, Virginia
    845
    You can get braided steel lines made to any length you want at most speed shops and some select auto parts stores, I had one made up a few weeks ago when I put an extended swinger on my one Tecate, but it likely wont be very cheap for one the length your talking about as well as finding a way of keeping it in place without catching it on something. Are you saying that you are missing the rear master cylinder? What about your front brakes? are you saying your only going to run rears or your going to run front/rear of the same master cylinder (not a very good idea in my opinion)?
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
    PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
    1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
    My Feedback
    Dec 2011
    Ontario, Canada
    509
    Good question rodeo i have been wondering the same thing for my 84 200x when i got it it had just back brakes with 2 hoses joined with some kind of wierd joiner which i am pretty sure isn't supposed to be on the bike...so one longer hose would better but i haven't found one yet but i was thinking a auto parts store would probebly be able to hook me up but i haven't got around to that yet
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Dec 2011
    Park City, KS
    389
    Quote Originally Posted by HuffieVA View Post
    im not exactly sure what i wanna do yet. i dont have the foot lever, master cylinder, hose, or rear caliper. the only thing i had for front brakes was the caliper. no hose, master cylinder, or lever either. i just need front or rear right now. on brake is better than none
    1986 Honda ATC200X
    Dec 2011
    Ontario, Canada
    509
    your trike sounds alot like mine is.....for now lol but i have the front master cylinder running the rear with a ghetto set-up....i would go rear for sure though if you only run one
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Dec 2010
    washington state
    681
    someones gonna get hurt, check ebay less then 100$ you should be able to get both brakes working ,, stay of hills if you only have rear brakesgood luck
    GOT MUD?:
    Dec 2011
    Ontario, Canada
    509
    mine is gonna have both brakes,I am in the process of rebuilding it, it is in 100 peices right now around my garage lol but when I got it thats the way it was
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Dec 2011
    Park City, KS
    389
    Quote Originally Posted by 350XJEDI View Post
    does it matter what master cylinder i get for the front? since ive got the front caliper, i just need the hose, lever, and master cylinder. do i HAVE to get a 200x lever/master cylinder or will a cheaper one work?
    1986 Honda ATC200X
    Aug 2009
    845
    Pretty much any front master cylinder will (can be made to) work, it depends on the hose ends and which way they mount on the caliper/master, basically if you are getting one made they need to know the angle of the end of the hose (generally straight or 90 degrees) on a side note the +8" steel braided line I had made up for my Tecate was around $25 but obviously rear lines are shorter than fronts so a longer hose will cost you more. if you figure around $1 an inch you should be covered
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    My Feedback
    Dec 2011
    Park City, KS
    389
    what can i do for rear brakes? cause the foot lever is $35+, master cylinder is close to $100, and i dont even know about the hose/line. i just dont have that much money, still bein in high school. any ideas on how to do it cheap, but still make it work?
    1986 Honda ATC200X
