Results 1 to 3 of 3
Thread: 200x carb re-jetting
    Dec 2011
    Illinois
    15
    hey! i was just wondering if its possible to put a bigger jet in a stock 200x carb. and if so what all has to be done? what are good jet numbers to use if most everything else is stock?
    Jun 2009
    Leander TX
    2,217
    Yes - you can put bigger jets in.
    If everything is stock, use the stock jets.
    Stock main jet is either a 110 (83) or 108 (84).
    What are you trying to do? Has something changed (intake, exhaust, cam) or is it not running right?
    What's the plug say? Good jets to try are based on what the plug tells you.
    Dec 2011
    Illinois
    15
    well i put i different exhaust on it. i just wondering if you can size up the jet to get a little more out of the carb or does more changing need to be done.
