Results 1 to 15 of 22
Thread: How many gears on a 84 Honda atc 250r
    ontario
    10
    Hey guys I recently picked up a sweet 84 250r but it feels like it's missing a gear. Pls help is this a 4 speed motor . So I got neutral 1 down and 3 up total of 4 speeds . Is this right. It's pretty fast but I think the sprockets were changed stock is 13/32 but mine is 15/45 tooth now is that a trail set up for faster low end . Pls let me know
    Blossvale NY
    4,563
    Should be a 5 speed
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    ontario
    10
    See that's the problem I've heared should be alot . Like should be 4 or should be 5 .
    Im looking for yes they were all 5 or yes they were all 4 speed . It determines weather I tear the motor apart or not . Or is there any easy way to find out .
    You've got a weird way of wording things.
    Like Ride Red said, it's supposed to be a 5 speed. What are you questioning?
    Oct 2009
    FF, Man.
    774
    Yes they were all 5 speed. I believe stock gearing was 13/44 for 81/82 at least. Higher number of teeth on front sprock = more top end, as does a lower number of teeth on the rear sprock. Hope this helps somewhat.
    Me and Fabs must have been typing at the same time.
    My 3WW Feedback Thread:
    Salut Gilles
    ontario
    10
    This how it goes when I start it up in neutral shift down for first and the up three times should it be up 4 times . To make I a 5 speed I'm just trying to word it in lamens terms so it's understandable. As the sprocket goes my question is answered for that. If I'm actually missing 5th gear I need to find out why. If got a repair manual on order hopefully that will help me
    Blossvale NY
    4,563
    Sounds like you do in fact have some kind of transmission trouble. Only way to tell would be to dis-assemble it and see what's going on. Could be a bad shift drum, shift fork or worse. When you try for 5th gear does it grind or make any weird noises? Or is it just not there? I hate to say it, but I think you are going to have to dig in to see what's going on..
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    ontario
    10
    Ya that what I'm thinking. The thing runs tits . I can throw 4 gears with ease I try or 5th and te shifter dosent even move no noise no grinding nothing just stays in 4th . Well thanks for your help I'm just gonna half to tear it apart
    Blossvale NY
    4,563
    Ok, hopefully it's something simple and inexpensive.. Let us know what you find.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    ontario
    10
    Ya will do I should have it out this week. Thanks for the help. If anyone has had this problem please let me know what u did or what was wrong thanks again
    Jan 2017
    San Diego California
    6
    1984 Atc250r no 5th gear
    Quote Originally Posted by spinner View Post
    I picked a 1984 250r rode it for a week and found it only has 4 gears. 1 down then only 3 up missing the last. Do not know what I should do
    2,591
    The first thing I'd do is to check to see if it has the shift pattern on the engine case by where the shift shaft goes inside the engine. This will tell you how many gears it's supposed to have. If it's only four, I would guess that you don't have the original engine on your trike. From what I can remember, the CR480 engines only had four gears. that's the first thing that came to mind when I read your first post.
    Jan 2017
    6
    Brushed off a good amount of mud around the shifter and couldn't see and visible depictions of the number of gears. My phones charging currently then I can take some pictures?
    HondaRidr's Avatar
    Salt Lake
    343
    I don't think the shift pattern is on the cases but I could be wrong. The 82 cr480 was 4 speed, 83 was 5. Take a picture and post it up
    Sent from my SM-G930T using Tapatalk
    Jan 2017
    6
ID:	239117Click image for larger version.
ID:	239118Click image for larger version.
