Thread: 1977 atc90 looking for manual or timing explanation
    May 2011
    The Granite State
    914
    i have a 77 atc90 and im looking for a free downloadable manual or for someone to explain how to set the timing. I had to take the cylinder off so right now the timing chain is off the cam sprocket. I downloaded this one http://www.oscarmayer.net/atc/manuals/ but i cant find anything about doing the timing. thanks
    EDIT: Also the high low range lever seems to be stuck in the low position. i cant push it over to high. I just got this trike so i dont know for sure but it looks like it hasnt run in a LONG time. Any insight on this would be great too!
    Sep 2007
    100mi west of Chicago
    3,582
    This one was pretty good when I was rebuilding my 110
    http://www.mediafire.com/?1sy3fgmuqu6e8c7
    Rob
    Baltimore, MD
    6,088
    Sometimes with the hi/lo gearbox lever, you have to rock the trike some back and forth to get the lever to switch gears. Remember, you are dealing with a 35 year old machine that not have always been treated the best. Do a search here on the site for downloadable manuals, they are here. It's alot to type out to explain how to put the cam back in and time it.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Page 57 of that manual you downloaded - the pictures are not very clear and the instructions are a bit brief but it is there. As long as you have your piston at TDC and your cam lobes are pointing down symmetrically your marks should line up.
    Bill
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
