I have a leaky bottom end (numerous posts), now I just want to fix it good enough for right now so that I can ride it. The problem, is, coolant is getting in the tranny, and the tranny/ coolant mix is going into the cylinder. What do I need to fix this? The water pump oil seal, and the right main bearing seal? Can I fix this with the engine in the frame or do the cases need split?
SOON MY PRECIOUS!
