Results 1 to 8 of 8
Thread: Odd question about the gear shifter honda 250r
    ontario
    10
    Ok I have brought this up before And this may be a stupid question bit if someone had the gear shifter arm out and didint put it back in in the right gear positioning when reinstalled is it possible to on have 4 gears instead of five. Im away home and cant wrench on. If it's not possible for that to happen I'd like to know thanks
    Michigan UP
    1,005
    If it goes through 4 gears just fine it should go into 5th. Look at the shifter and see if it hits anything, pretty simple
    4x4van's Avatar
    4x4van is offline At The Back Of The Pack Arm chair racerFirst time rider
    SoCal
    160
    Yup, the position of it, unless it is at an extreme so that it hits the footpeg, is irrelevant. If it shifts into one gear, it should shift into the rest. In fact, the position is a matter of personal taste; I run mine fairly low, while my wife likes hers higher.
    ontario
    10
    Well when I got it the shifter pedal was already set prett low too low for my liking but I left it for the time being . So I can take off and go through 1to 4 beautifully I try 5th and the pedal moves up a bit dosent hit anything but dosent go into the gear. No sounds no click no anything it's weird . Runs very strong . That's why i thought the actual Gear shifter shaft was actually put in wrong
    Is there an easy way to check
    Carthage NY 250r rules
    2,355
    It is posible to get the cogs off by a tooth if you didnt get the shifter shaft back in.I had it happen to my 300r a couple weeks ago when I put it together .I checked it by shifting the gears before I put the engine back in the frame.
    Nov 2010
    Oshawa, On, Canada
    2,123
    Are you sure you're not just unsure of the gearshifting pattern? 1, N, 2, 3, 4, 5
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    rodeofan5656's Avatar
    rodeofan5656 is offline Girlfriend wishes I'd last longer than 8 seconds Arm chair racerAt the back of the pack
    Dec 2011
    Park City, KS
    389
    Jason125m has a point. are you sure youre not thinkin that there should be 5 above neutral? cause once you get to neutral, theres only 4 gears above that
    1986 Honda ATC200X
    2005 Yamaha Road Star 1700
    ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
    2,355
    if the teeth on the shifter cogs are off by one tooth it wont let you shift into the last gear .They go together a certain way. Has anyone else had a tranny apart on one of these .Iv had 250rs since 85 and worked on them since then.
