Results 1 to 4 of 4
Thread: 200x cam question
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    200x cam question
    2 questions on a 1984 200x
    1. Is it the same cam as a 200s. ??
    2. Can you remove the cam with out taking the valve cover off ?
    Thanks !!!
    84 200s almost done
    84 atc 70 project
    Jan 2011
    Brazil, Indiana
    2,087
    Not the same cam, and yes you can remove it without dis-assembling the top end. Just be careful not to drop the cam chain in the hole.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Jan 2011
    Avon, Minnesota
    641
    NOT same cam BUT if you use 200x cam bearing it will work. since 200x cam is better than 200s it will give u boost in performance
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Dec 2005
    Wisconsin
    1,141
    What they said! Hold the cam chain up with a screwdriver while you are taking the cam out. Then if you put a big enough zip tie around the chain it will keep it from falling down to the flywheel.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
