Results 1 to 15 of 17
Thread: Need help!!!
    Oct 2011
    Subligna, Georgia
    51
    Need help!!!
    Went to put my new hub and tire and wheel on my 200m which are stock hub tire and wheel.i didn't tighten it all the way down but my tire is rubbin the fork??? Why???
    1984 Honda ATC200M
    2009 Honda Rancher 420AT
    Omaha, Ne
    42
    could you possibly have a different fork from the original?
    Oct 2011
    Subligna, Georgia
    51
    I just replaced the forks they are original forks the only thing I can think of is the triple trees are different....does anybody have any measurements of the width of triple trees at the widest part on stock 200m? Measure outside to outside if u do
    1984 Honda ATC200M
    rodeofan5656's Avatar
    rodeofan5656 is offline Girlfriend wishes I'd last longer than 8 seconds Arm chair racerAt the back of the pack
    Dec 2011
    Park City, KS
    389
    are there spacers that are supposed to be on each side of the hub, on the axle? or are both side of the tire rubbin on the forks?
    1986 Honda ATC200X
    2005 Yamaha Road Star 1700
    ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
    Gold Hill, OR
    1,295
    A picture would be really helpful if its not too much trouble.........
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Tionesta, PA
    5,747
    is it rubbing both sides? You didn't get a 200S or 185S front end did you? Also, do you maybe have the wheel on backwards? Valve stem should be opposite side from brakes
    Oct 2011
    Subligna, Georgia
    51
    the wheel is on correct and i only have one spacer is there suppose to be 2? where do they go?? its rubbin the opposite side of the brake Click image for larger version.
ID:	140631 Click image for larger version.
    1984 Honda ATC200M
    Oct 2011
    Subligna, Georgia
    51
    any ideas from the pics?
    1984 Honda ATC200M
    Oct 2011
    Subligna, Georgia
    51
    if u need better pics jus let me know what to take them of
    1984 Honda ATC200M
    Dec 2011
    Ontario, Canada
    509
    Is it rubbing on both sides? i have a 200m and when i put the baby down for a nap i will go measure and look at the spacer situation for you ok
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Oct 2011
    Subligna, Georgia
    51
    no only on the side opposite of the brakes...thanks a lot man!!!
    1984 Honda ATC200M
    Tionesta, PA
    5,747
    Did you replace forks only, or forks and triples? By the looks of your picture, there is not much room on the side that is not rubbing.
    Oct 2011
    Subligna, Georgia
    51
    no i didnt change the triple trees it did have the wrong front hub and tire and wheel on it tho when i got it i just wanted to make sure there wasnt a simple sumthin i was over lookin before i dove into gettin new triples
    1984 Honda ATC200M
    Oct 2011
    Subligna, Georgia
    51
    Hey jjmf1979 did u get a chance to take those measurments
    1984 Honda ATC200M
    ARKANSAS
    41
    tire to wide ?
