questions with T3 timing..?
i bought a new stator and flywheel for my '86, and the two holes that the plate mounts to the engine are slotted, how do i know for sure where the plate should be bolted? when its in and move the plate clockwise, it retards the timing and vice versa right? its a magnetic flywheel and not the glued on POS one, if it helps.
You should see 3 marks on the stator. There is a long one with 2 shorter ones on either side. There is a pointer (really just a bump) cast into the case. Align the right hand mark on the stator (the shorter one) with the pointer on the case. That's it!
'8? ATC70s
'8? ALT50
'8? YT175
'83 ATC185S
(3) '85 ATC250ES
(5) '85 YTZ250
(2) '85 ATC250R
(5.5) '86 KXT250
'86 YTZ250
'86 KXT500
'86 ATC350X
'87 KXT250
'87 ATC250SX
and a couple of Mancos
alright that helps alot, thanks 250sx
//ArrowChat Integreation Code
