Well i cleaned the carb with seafoam, let it sit over night, blew out all the air passages the next day. then i installed all new jets....45 pilot...470 main and yamalube 24:1 92 octane. Bike starts right up. Still smokes the same out as it did at 32:1. I let it warm up and tried to make some adjustments to the air screw. Turning the screw all the way out did not raise the rpms at all. I wonder if the pilot jet is to rich. Maybe i should go down one more step. One other thing thtas kinda wierd. I cant get the bike to idle with the idle screw screwed all the way in. Its like it doesnt raise the slide enough. I have to adjust the cable up by the handlebars to get it into an acceptable idle range. But once i do that, if i turn the handle bars to the right, the throttle revs a bit. I will have to look into it some more i guess. Thanks again
Ill get a video up in the next day or so.
1986 ATC 350X
1986 ATC Big Red 250ES
