Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: 1986 250SX Resurrection! An ATC saved! More build pics added and to come
    Plattsburgh, NY
    2,311
    so this is an '86 Honda ATC 250SX that i got in a trade of value for $200. it was so hacked and molested i couldn't believe it, but none the less i had to have it.
    as u can c, the muffler was hack sawed off, fenders spray painted, gas tank painted by brush with house type paint, patched all over the seams, dented all over, and an RM dirt bike front end. so no front brakes, and no steering, lol. it would push so badly in the corners it was ridiculous, plus the front end was much higher and much lighter. i was told they did this to "win in drag races!"
    amazingly though the trike ran great, started no problem, and even reverse worked. when i got it home, i changed the oil and filter, and checked the sir filter which was the inner foam of a couch cushion wrapped in duct tape. so i got a new OEM filter and installed that and put a battery in it and even the electric start worked perfectly.
    so even though it looked the way it does, it actually ran well, shifted through all the gears, and the headlight and taillight work and electric start.
    so i have been slowly chipping away at going through this and restoring it. i am not going for a show room build and it is not done yet. but i had to post some comparison photos. most people i know didn't believe it was the same trike but it absolutely is. i still need to do things like that paint and powder coat small things and give it a full cleaning.
    also that is the same gas tank.
ID:	140670Click image for larger version.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Wow man! You really had your work cut out for you there! Holy hell, what a hack!
    Way to bring em back to life!
    Trailpros
    Springfield Mo
    3,309
    Dayuuuum!!! That turned out good!
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Beaver Falls, PA
    2,666
    Great job... nice MC wheel in the original!
    May 2009
    S.E. Michigan
    1,251
    Holy resurections, Batman! That is an incredible transformation. I'm working on my 86 SX right now as well, but my starting point was way better than your starting point... and I don't mean that to sound rude, just the opposite, it is amazing how amazing the machine looks now.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    STL
    3,560
    holy crap!!!! really turned that thing around! that front end was ridiculous looking lol great work man
    Florida
    100
    I love seeing threads like this, great save! That thing could have easily been parted out, but you put the time, money, and work into it to bring it back to life. Well done.
    Big Mike's Avatar
    Hanson, MA
    1,062
    HAHA Looked like something you would have seen in a Mad Max movie, looks absolutely amazing now, GREAT JOB!!!
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    Nov 2010
    Oshawa, On, Canada
    2,123
    What a great transformation! Great work Tatool.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jun 2009
    Leander TX
    2,217
    Nicely done - I bet the Amex got a workout - could not have been cheap to do.
    Jul 2011
    Ontario/Quebec
    1,179
    nice job ryan!!!
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    Plattsburgh, NY
    2,311
    you can c here they also spray bombed the entire throttle while on the machine because of the headlight shell having over spray from it. they tried using the same headlight shell on the thinner spaced forks so they just pulled it in so far that it cracked the headlight shell. you can also c a little more of how bad the gas tank was. but amazingly it was like brand new inside. which is y we restored this tank.
    and we had already welded the muffler back on.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Plattsburgh, NY
    2,311
    and here is all i could c of the stock seat cover. there was a little bit of blue showing so i really wondered if there was a perfect shaped OEM seat under the plastic and foam they put on it. from the rest of the trike i wasn't counting on finding anything good under there. here it is with the homemade cover and then after cutting it off.... the pics speak for themselves. in the second pic u can also c the horrible paint on the tank and the sweet foam grips with electrical tape.
ID:	140707Click image for larger version.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    1,641
    Wow!Really can't say much else.
    Nov 2009
    N Hollywood/ CA
    588
    They would of won more races if they didn't have the 's lol
