Cylinder Sleave
well it has come time to rebuild my 225 dx. i got it pretty much tore apart. i was curious if i buy a cylinder sleeve, how it can be changed. i know with my Polaris, i had to get it bored out all the way for that go slide in, but i heard that in some cases you can heat up the cylinder in the oven and press it out. i have a 4 ton press and was wondering if that would work of if i should just get it bored ?
thanks
Jimmy
Yeah get it bored. Even a new sleeve needs to be bored to size.
Are you on your last bore?
no im not, i was just curious
If you're not on your last bore then why are you sleeving it?
//ArrowChat Integreation Code
