Thread: help identifing this 86 tecate exhaust pipe
    Mar 2003
    NJ
    911
    hello,
    can anyone tell if this fmf pipe is for the kxt. im afraid of buying a kx pipe. the owner says it clears everything. are the kx pipes that different that there is no chance of confusing them.
    thanks for your help.
    thanks,
    mark
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    May 2002
    Texas
    2,670
    I bet 200xbasket can help you. He put a pro circuit pipe from a 86 KX onto his. He did have to do some mods.
    I have two stock pipes and they have some bends out above the coolant tank. I did notice DG pipe for KXTs were pretty straight and rode higher above the coolant tank than stockers.
    Tough to tell.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    JBKX is offline New to the board Arm chair racerNew to the board
    May 2003
    27
    Pipe
    FMF never made a KXT pipe. I had one ordered in late 1987 for my 86 and they decided not to produce them. They never developed them past pre-production is the story I got. So I settled for a Bill's Pipe and never had any complaints. That pipe looks a lot like a DG unit.
    3 1986 TECATE'S ( 2-KXT250'S 1-KXT500)
    2001 KX250 with '93 KX500 Engine
    Jun 2002
    Mississippi
    2,552
    a kx pipe will not fit without welding and bending. that really looks liek a stock pipe to me.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Mar 2003
    NJ
    911
    i thought that pipe looked stock also, its not any fatter than stock. also its missing the four bolt holes for the rubber stops in the back.
    thanks for the help guys.
    anyone out there willing to part with an aftermarket pipe?
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
