 Got The Holeshot
						Arm chair racerJust too addicted
						Got The Holeshot
						 Got The Holeshot
						Got The Holeshot
						did not see any numbers on it.
best way to tell is if you got a stock cam and you put it next to it. Not all cams are equal as some will open the valve sooner and more. Some wont. If you had a stock cam hold it need to this one and look at your lobes to see if its fatter or taller than the stock one. Other than that there is not really a way to tell just by looking at it.
85 ATC 250r -Under Construction
86 TRX250r
05 KFX400
02 400EX
 Got The Holeshot
						Got The Holeshot
						do not have a stock one to compare it to.
 Got The Holeshot
						Got The Holeshot
						does anyone have stock measurements of the height on the lobes
From the Honda manual:
Intake: 1.2739-1.2802
Exhaust: 1.2615-1.2678
If they aren't the same, please post your results.
 Got The Holeshot
						Got The Holeshot
						cool thanks will have to take it to my buddies shop and check it out.
