81 185s questions.
That decompression switch thing isn't hooked up on my ATC, I heard it hooks up in the pull start. Where exactly does it hook up too?
#2 all my hoses are all gone exept for the crank case vent, can someone explain where the hoses go? Or pictures. And when I pull to start it it spits out gas from the bottom of the carb, what does that mean? Is it suppose to do that?
#3 can I time it without it running? I'm thinking the timing is off but I can't check it cause it doesn't start.
#4 I don't have an air filter on my ATC could that cause it to be a PITA to start?
Sorry for all the questions, I wanna ride my ATC and I'm so close to giving up
//ArrowChat Integreation Code
