Results 1 to 8 of 8
Thread: my trike hauler blowing fuses
    Hampton, Virginia, C.S.A.
    2,664
    ok so ive got a 2008 6x12 enclosed american hauler trailer...we have towed this about 5 times before and never had a problem with it blowing a fuse...i had about a 25 mile drive back home last night and it was raining...the lights went out a bout half way home...so i put a new fuse in today and as soon as a turned to light on it poped i then tried another and it poped again...so i unpluged the lights cause i was out of fuses lol...and it seemed like there was alot of water in the plug...do you guys think thats the problem? it just seemed to me like there would always be water in these plugs if it raining...or are they sopposed to be sealed? i might add this was the first time id ever had to tow it in the rain
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Baltimore, MD
    6,088
    trailers can be messed up for such things. You could have a pinched wire or a wire with some insulation rubbed off of it. You could have a light with some water in it. Water at the plug could be a factor. The only way to know for sure is to dry out the plug with a hair drier and try again or start going over all your wires.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Gold Hill, OR
    1,295
    I have been chasing a flickering problem on my 6x12 Cargo Mate for a couple years lol..........
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    2,664
    Quote Originally Posted by ezmoney1979 View Post
    thats what worrys me...ive got to use this trailer next saturday evening to get my band equipment to a very big gig we got...im letting it dry out and see what i can do tomorrow after work
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Trailers are notorious for having rusty grounds (flickering lights) or a hot grounding out from water/pinching/wearing etc (blowing the fuse).
    My truck signal lights would stop flashing once in awhile. Thats usually a bulb, bad ground or flasher issue. I traced all the relays, the flasher, all the wires, cleaned all my grounds etc etc. As soon as I unplugged the trailer extension and threw it away, the lights were perfect. Something was backfeeding something; Thank god I don't have a tralier
    I bet I spent 12 hours tracing that crap out when the 1st thing I should have done was unplug the trailer harness to rule it out.......
    London, Ontario, Canada
    1,059
    I've never had a trailer that didn't need a full wiring re-do after about 4-5 years. They are wired at the factory so quickly and cheaply it's a wonder they last that long. You'll find wires stapled to the wood floors, run thru torch cut holes, drilled holes (raw edges), un-insulated butt connectors, even household marretts. Personally I would look at the overall condition of the wiring under the trailer and if nothing obvious grabs your attention you can do a complete re-do in the same amount of time it takes to search out the issue.
    Do it once and do it right.
    Sealed 7 pin junction box up front on the tongue so you can replace the plug and lead as they are the easiest to get damaged
    jacketed wire to the back and brakes held in place with cushion clamps. i run a three wire down each side to pick up the tail,stop/turn and ground for that side, and a dedicated two wire for clearance lights and a second dedicated two wire for the brakes. all connect in the junction box and could be replaced individually if ever needed. All ground also come back to the box,(no wiggling of the lights to get them working)
    all connections should be covered with adhesive filled shrink wrap for a watertight seal
    I also prefer sealed LED's, Never have to change a bulb again.
    I just take it as part of trailer ownership that at some time it will need to be re-wired. Hope you sort it out
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    Crest California
    3,014
    ^Agree, you can pick up spools of good quality wire from Amazon for about $12 a roll, and assorted packs of heat shrink tubing- you don't really NEED adhesive filled, but the stuff does work pretty well (as long as it's done right the first time). Very handy to keep around. I personally love doing wiring, so re-wiring a trailer would take me probably 4 hours-ish, yeah I've gotten good at it you might say
    BTW, die-electrical grease is handy to have on hand. Those connections you can't insulate with heat shrink (like those inside of a plug housing or something) you can at least protect against the elements using the stuff.
    LED obsessed
    2015 Yamaha FJ-09
    2,664
    thanks for the suggestions guys...i found the problem after about 30 mins...all grounds looked good and clean...so i traced and wiggled wires till the came on...i found a bad crimp on a positive wire under the right side fender...to bad it got dark or it would already be fixed
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
