Results 1 to 11 of 11
Thread: 250r coolant fitting on head came loose
    Nov 2009
    Okauchee, WI
    555
    The coolant fitting on the head of my '85 250r came loose yeaterday while riding. It came out of the head a good 3/4 inch. What would cause this? Fixable? Looks like it's pressed in. New to the 250r's, just got mine finished. It felt pretty dam good before the fitting letting loose.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Las Vegas, NV.
    2,488
    I've never seen that happen before, and I agree, it appears to be pressed in. I would remove the head, clean it & the elbow up nicely, and then epoxy the elbow back into place.
    May 2011
    Utica, NY
    45
    Was she hot when this came apart? You should look into why this has happened before you simply "glue" her together and continue ridding her.
    Nov 2009
    Okauchee, WI
    555
    Didn't seem to be hot at the time. I was kinda babying it around the track at the time. I have a extra head that I treid twisting and pulling on the fitting and it doesn't budge. This has me clueless. Engine has a fresh top end.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    gus's Avatar
    gus is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2011
    tucson arizona
    453
    wow i never seen this happen also?? are they suppose to come off like that?
    Jan 2005
    RI
    2,530
    just weld it up and be done with it
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2010
    Ontario Canada
    121
    I had this happen to me once, I was out playing on the lake. It was damn cold out that day. My water pump impeller was broken (dont know how that happend) and i think the head got way too hot too fast...i dont really know. Change the head if you have another one
    Las Vegas, NV.
    2,488
    Quote Originally Posted by ktm one View Post
    I totally agree, but if you believe this happened due to excessive pressure in the coolant system, there are many other weaker links that would have let go first, before it would blow that spigot out of the head. That's why I believe the spigot was weak to begin with and just needs to be secured.
    Apr 2010
    Ontario Canada
    121
    There is NO way that cooling system pressure would push that out. The rad cap and hoses would blow off before that would ever happen! Change the head.
    Nov 2009
    Okauchee, WI
    555
    Ya, I don't understand why it hapened. Everything was working. Just musta been it's time. I'll have to order a head gasket and swap heads.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Apr 2013
    Bakersfield CA
    33
    I know this is an old thread but I was hoping to get more insight on this issue if anyone can assist. Don't mean to highjack but didn't see a need to start a new thread. Not sure if I'm just lucky but I've had this happen twice on two different 250Rs
    First was an 85 that was jetted incorrectly it overheated and popped out the elbow. I re jetted it put a new used head on it and its been running great for years.
    Second is an 86 I recently purchased. I'm still getting to know the bike but it popped the elbow last weekend in Dumont and I'm not sure why.
    My question is are these press fit or sweat fitted in ? Should I look for a replacement head or install the elbow ?
    Thanks !
