I have an internal rotor motoplat ignition on a 86 t3. the stock timing is 14or 15 degrees btdc @6800 rpm (I dont have the manual in front of me) I know the advance is in the stock cdi unit and I'm guessing the motoplat doesnt advance since its kinda a universal set up. I set the timing @ 13degrees BTDC but it just does not run right. It will rev while riding and the plug chops look good but it just doesnt have the top end power it should. with no load it stutters @ 3/4 throttle like its on a limiter.I tried to find info on this ignition with no luck. There is a company that repairs them but when I emailed him to get any info all he could tell me was that when then hash marks are lined up it fires.(thanks bud I think I figured that out) does anyone run this type of ignition? does the cdi/coil advance.(one unit) a base timing? any helpful info would be greatly appreciated.
