Thinking of upgrading my carb on my stock triz. most of the parts that are wore out are obsolete. (my bent 6h3 needle & and 2.0 slide)what would you recommend? i spose i would have to ger a 250r 85-86 cable to make it work. thx!
Go look at JetsRus. I suspect you'll find any part you might need there. If you do buy a new carb I'd suggest a 38mm Keihin.
Stock 250r 34mm kehins work well on tri z
