Thread: From Hennessey Oklahoma
    Aug 2011
    Hennessey, Oklahoma
    7
    Been around a little bit doin alot reading, but didnt introduce my bike until I got it done. Its an 1981 atc 200, 12:1 Wiseco piston on 110 gas, ported and polished head along with the intake port matched to a 30mm carb from ebay. Header is a 1 3/8 header off a 200x and the mid pipe is 1 1/2 I bent. Dont laugh at the muffler, its an exhaust resonator off a new 2010 Camaro, I still need to fasten a good hanger for it, what I have now is just temporary. It's also got a 200x front triple clamps, forks and wheel on it. 1st gear was pretty much pointless so I put a 12t sprocket on it.
    On the carburetor I had no clue what jet was in it, it was too lean. Started with a 105 jet and if you gave it gas real quick it would stumble. Ive got a 110 in it now and its still a bit on the lean side. This thing has a killer top end, bottom end isnt bad, keeps me from going over backwards but I think I'll end up with a 115 jet. Also had to notch the thumb throttle assembly to get it to go wot.
    I took the stock front assembly off and cut off the steering stem, cut it down and machined a piece on my lathe that fit up inside the stock piece and welded it up.
    STL
    3,560
    Handy man, that's an interesting exhaust! Sounds likeyou know what your doing so far, welcome!
    Aug 2011
    Hennessey, Oklahoma
    7
    Ive been around them since I was a little kid. I worked in a dyno/performance shop for 5 years and been around alot of different cars and have my own dirt track cars that i build my own racing engines for. I know a little bit but far from knowing it all.
    Feb 2012
    Elgin,OK
    28
    Welcome. Im from Elgin,Oklahoma
