Results 1 to 15 of 24
Thread: Bearing seal question and my 83 200x back rolling
    Dec 2011
    Ontario, Canada
    509
    So i can't get an answer on .org so maybe i can get one here....the thing is i got an all balls rear axle bearing kit and it had two bearings and two seals, then an extra different looking bearing seal which the trike did have when i dissassembled it but i can't remember where exactly it goes i did put it where i though it made sence to go but lets see if i was right....let me know if you know it didn't show it in the swingarm diagnostics on the service manual and the bearing kit didn't have instructions of course. also here is a pic of my newly reassembled 200x roller
ID:	141825Click image for larger version.
ID:	141826Click image for larger version.
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Jul 2011
    Lilly PA
    1,480
    I just replaced the bearings in my 83 200x and dont remember any other bearing than the 2 and then the 2 dust seals. Where exactly did you put this bearing and what does it look like?
    Just sit back and chillaxx
    Dec 2011
    Ontario, Canada
    509
    Quote Originally Posted by 84t3 View Post
    sorry i fixed that....i meant a third different bearing seal just like the one in the picture
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Oct 2011
    lower sackville , Nova Scotia
    35
    i also received the extra seal with my all-balls kit for my 200x , its just an extra since the kit supports several makes and models.
    Dec 2011
    Ontario, Canada
    509
    well the funny part is i removed one off the bike when i dissassembled...thats the one that the picture is of... so it must go on somewhere
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    6,811
    Yep it goes in the trash can Universal kit so that seal is not for your bike .
    [QUOTE=JJMF1979;1100717) . so it must go on somewhere[/QUOTE]
    Dec 2011
    Ontario, Canada
    509
    Wish i could remember where i took it off of when i dissassembled
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Northern, California US
    105
    Like shortline10 said its useless for your application.
    Dec 2011
    Ontario, Canada
    509
    i have the same schematic in my service manual. but if you look at the rear axle schematic you will see some kind of seal or washer slid on to the axle when you slide it into the swingarm so i tought maybe that was what it was for
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    105
    Those are o-rings there should be two of them.
    Dec 2011
    Ontario, Canada
    509
    are you sure? there was only one and only one came of the trike when i dissassembled.....how come no one else knows what they are? and where to they go they weren't on the schematics....i guess i have two if i need them because the old one is still in good shape
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    105
ID:	141983Click image for larger version.
Name:	Screen shot 2012-02-12 at 7.00.31 PM.jpg
    Alright if you look at the pictures the arrows are pointing at the o-rings I'm talking about. One diagram is straight outta the service manual and the other is a parts diagram, because both have them shown I'm pretty sure there supposed to be there.
    I could be wrong it's been awhile since I pulled a 200x rear apart but I'm almost positive that they fit in there.
    Dec 2011
    Ontario, Canada
    509
    want to hear something funny.....i saw that axle schematic and put the one i had right where it shows on the service manual because it fit right in there....but are saying i should put one on the brake rotor side too because i do see where the old one i have would fit right in there, there is a little gap between the rotor and swingarm even though everything is tight
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Wait a second, didn't you get one odd seal type thing??
    Axle bearings/seals do not come with brake rotor hub o-rings...............EVER!
    Dec 2011
    Ontario, Canada
    509
    ya it's a seal and there is a picture at the top of the thread and i don't think it is an o ring but it do think that what is shown in the service manual schematics might be what i have but i am so confused at this point lol i slid it on the axle before i put the axle in the swingarm all the way up to the flat ring on the axle and it fit right on there perfectly so i thought that must be it, anyways i sent a message to who i bought the kit off of and maybe since they sold it to me they know what the parts are for
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
