Results 1 to 11 of 11
Thread: klt110 doesnt have full power. need help!!!
    Feb 2012
    southern catskill mts.
    7
    just picked up one ratty old 85 klt110. from what ive read, they were one of the quickest little 3 wheelers for that size. i just got new carb on, checked valves, new plug and air cleaner, compression is 100psi, fresh oil. auto clutch adjusted properly. it just doesnt seem to have much power. unless im movin at a good clip, i have to shift into 1st to go up any incline. plug is pretty dark but im up to the second clip groove from top on neddle. am i just expecting too much from this machine. im 190lbs, but my xr80 sure didnt have problems movin me around. what do you think?
    Aug 2011
    ferndale wa
    10
    make sure the choke is off.
    Feb 2012
    7
    Quote Originally Posted by james200x9619 View Post
    ha ha ha. make sure the run button is in on possition too...
    Feb 2012
    washington
    83
    try the old carb ( try cleaning in first ) and see if its better performance. some new carbs are crap also run without the air filter ( for a few minutes ) sometimes crap is in the rubber between the head and the carb. good luck
    Feb 2012
    7
    really folks, ive been through all the basics. what should the compression be?
    hogmuffin's Avatar
    hogmuffin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Dallas, TX
    341
    according to the service manual, compression should be 164-192 PSI.
    1985 KLT 160
    1985 YTM 200ERN
    1984 YT 60
    Reproduced KLT 160, 110 decals for sale
    Reproduced YTM200ERN decals for sale
    http://www.3wheelerworld.com/album.php?albumid=2655
    Feedback thread: http://www.3wheelerworld.com/showthr...uffin+feedback
    hogmuffin's Avatar
    Jun 2011
    Dallas, TX
    341
    might wanna pull the head, inspect the valves, and cam for wear
    1985 KLT 160
    1985 YTM 200ERN
    1984 YT 60
    Feb 2012
    7
    i cant believe after many mths this piece of crap is back in my garage. still doesnt have full power. good up till 3/4 throtle then boggy and no power. when the cdi goes out on these, do they fade out slowly or are they just good or bad? checked timing and its spot on.
    Slidell, LA
    4,738
    did you read the posts above? 100psi is weak for that machine. According to Hogmuffin your bike should have between 164 and 192 PSI compression reading. Have you checked that lately?
    Is it smoking? If not, I would bet your compression ring is ghandi.
    Feb 2012
    7
    i have a cdi box from a china made atv 125cc, would it be crazy to try that on my klt110 just for giggles
    Dec 2010
    Bethalto
    11
    I had a klt110 a while back. It had no compression when I got it, rings were worn bad and piston heavily scratched. I found a newer piston and rings on ebay threw it together and it was a good running little bike. It wasn't a major powerhouse but it was decently quick and would climb hills pretty easy. Definitively ran good for 110cc. Also that Chinese CDI could probably be made to work. I have rewired other bikes to run off them (XR80-100s).
    82' ATC 250R
    85' ATC 250R
    85' Tri-Z 250
    85' Tri-Z KX500 Powered Green Frankentrike Project
