Page 9 of 12 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 121 to 135 of 167
Thread: Project 185s High Performance ATC Full Suspension
  1. #121
    Miami,Fla.(305)
    808
    Wasnt too bad here- just few squalls- the worst appears over.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
  2. #122
    jsmay's Avatar
    jsmay is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2005
    Hendersonville TN
    593
    the blue is killer. And I hope you guys are safe down there...
    200x race parts needed
  3. #123
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    just wondering... whats the front tire/rim combo?
  4. #124
    6,811
    8"x 6" wide front rim with a kenda 20x7-8" inch front max tire . Works very well .
    Quote Originally Posted by jsmay View Post
  5. #125
    Oswego, IL
    1,858
    What kind of rope do you use in the pull starters on the bigger motors? Any thing special?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
  6. #126
    6,811
    1/4" marine grade nylon rope for the 185/200 and 3/16" for the 90/110 .
    Quote Originally Posted by vartiak15 View Post
  7. #127
    6,811
    Motor
    Been playing around with different motor parts to get the most out of her , decided to go with a megacycle 435 lift cam and the Custom ATC ported head I got from Mrclean and I think I got her now , what a beast ! Also installed a chrome aftermarket recoil for a little more bling .
    Attached Thumbnails Attached Thumbnails 2012-10-07_13-17-45_78.jpg   2012-10-07_13-17-55_373.jpg   2012-10-07_13-18-05_973.jpg   2012-10-07_13-18-17_698.jpg
  8. #128
    Slidell, LA
    4,738
    Very Nice mike! video please.
    By the way, I am getting ready to get a number plate from John for my 200x. Can you tell me what size numbers those are, where you got them and how you mounted them?
  9. #129
    6,811
    I have about 200 NOS maier numbers , they are 8" and fit perfect . They bolt on with plastic screws which they come with . What numbers are you wanting and what color white or black ?
  10. #130
    Slidell, LA
    4,738
    Do you have the numbers 7 and 6 in black?
  11. #131
    6,811
    Will look tomorrow .
  12. #132
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    I'd be interested in an 8 and 3 in white......
  13. #133
    NEPA
    7,051
    Damit Mike,,That is the PERFECT Little hot rod !!!!!! I love that badboy !
  14. #134
    6,811
    Will look tomorrow , white has yellowed a little on some of them but I will check .
  15. #135
    6,811
    Bill , this little bugger is a blast to ride , the low stance and the geometry of the frame makes it handle great , would make it an awesome little tt racer .
    Quote Originally Posted by atc007 View Post
