Results 1 to 9 of 9
Thread: whats a tri z like with yamaha rench report mods ??
    potsdam NY (upstate)
    1,437
    i was wondering if any one that has done the yamaha rench report engine mods can tell me how much more power it gave them and if it was worth it. ill be doing the rench report cylinder mods and carb mod also with they exception of im putting a dg pipe and silencer on mine. and im plaining the head a full 20 thousanths and ill be raising the cylinder port a full 2mm. im not doing thow work my self tho ill be sending the jug off to get this all done. what should i expect out of it when i get it back.
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    davham's Avatar
    davham is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    211
    I would like to know the same thing but I'm more interested in the phase one mods instead of the full blown on/off powerband.
    Dave
    May 2003
    Houston, Texas
    2,409
    I have never ridden one but from what I understand you do lose some low end power.
    I have never ridden a 250 which has alot of power all over the rpm range. My honest belief is that you have to make a compromise.
    If you ride a 500 then you can expect power everywhere (like my Quadzilla) but don't expect it from a 250.
    I would rather have my low end and mid range then all top and mid with no bottom.
    ANOTHER THING I WOULD LIKE TO SEE IS SOMEONE FIND AN OLD BIG BORE KIT FOR THE TRI Z OR YZ. THERE USED TO BE A 360 KIT FOR THE YZ AND A 317 KIT FOR THE TRI Z.
    FIND ONE OF THOSE AND YOU WON'T LOSE POWER ANYWHERE. YOU WILL JUST GAIN IT EVERYWHERE.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    1,437
    yeah that would be nice to have a big bore kit out there to buy with replacement pistons for the kit also. there are a couple mildly modded 250r 3 wheelers and 4 wheelers in my area but nuthing specail that id like to be able to spank.
    Mar 2003
    West Monroe, LA
    847
    It can finally keep up with a 86 Honda 250R...LOL j/k 8)
    1,437
    i dont think it would realy take much at all
    Ashland City, TN
    2,576
    Quote Originally Posted by TRI-Zbrian
    Neither do I. It is my belief if you level the playing field(ad the second cylinder boost port(Like an R or a T3), put a clamp on filter on(the stock is a choker), add a 34mm carb(like an R or a T3)) and you will have a very strong competitor for an R or a T3.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    mbg75 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    Long Island
    256
    my tri-z is for sale and the wrench report mods are done already. anyone interested email me mbg75@optonline.net
    Back on 2 wheels for now!
    clean 86 350x for sale.
    Sep 2003
    129
    I dont have any experience with Tri-Z's, but have built up many 2-stroke engines. Raising the exhaust port is what kills low end power. If you raise it 1-2mm that will give more top end, with a minimal torque loss. If you raise the exhaust 3-4mm it will usually kill low end, but the top end will be awesome. Cutting the cyl. head will increase torque and mid range power. A larger carb and or better filter will also give all around power gains. So basically,stay conservative on the ex. port timing (raise 1mm) to keep good low end, but perform the other mods for overall power. Just my experience.
    84 200x (modded)
    82-84 250r (basket case)
    80 110 (project)
    95 thundercat
    84 indy 650
    When in doubt: STAND ON IT!!!!
