Results 1 to 11 of 11
Thread: 200x timing chain noise / adjuster question
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    Have a lot of timing chain noise on my freshly rebuilt 1984 200x. It has a new. Timing chain i attempt to aadjust it but the noise dosent go away . I do have spring action on the adjuster .
    What gives ?
    If the adjuster is broken can it be removed with out taking the head off ?
    And risk of damage runnin it while its noisy.
    Thanks for any help or ideas .
    84 200s almost done
    84 atc 70 project
    Jan 2011
    Brazil, Indiana
    2,087
    Yes the adjuster can be accessed from the side of the motor.
    The chain is likely slapping on the side of the cylinder and head. Over time it will chip away some of the aluminum and find its way into the rest of the motor. I would take care of it as soon as possible.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Dec 2005
    Wisconsin
    1,141
    Are you sure it's cam chain making the noise not the rockers? The Adjuster that is like a bow you can replace without taking the head off. You need to remove the upper bolt that holds the adjuster on, then remove the flywheel to get the bottom apart. The guide on the other side you will need to remove the head to replace.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Dec 2011
    Ontario, Canada
    509
    I have sort of the same issue with my 200m. I can hear a slapping noise but only when I give it gas not when it is idleing, and only for a second when i give it gas..... then it stops would this be the same issue? I thought it might be the drive chain being a little loose and hitting on the case that sourounds that chain that 200m's have since it only does it when I just start moving.....any ideas? I havent taken a close look at it due to unheated garage lol but am going to soon
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Dec 2011
    Ontario, Canada
    509
    Quote Originally Posted by PAPA250r View Post
    What gives ?
    Hi Papa does your trike make this noise while idleing?
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Feb 2009
    greentown PA
    389
    Thanks for the information if its a broken adjuster im glad i dont have to pull engine/head to swap it
    Yea im positive it is the chain because the noise changes when i fiddle with the adjuster . I did check the valves also.
    Jjmf1979 -
    Yes mine does make the noise at idle basically at all times . Sometime the cdi/ spark advancer can make wierd noises also .
    84 200s almost done
    84 atc 70 project
    Dec 2011
    Ontario, Canada
    509
    Jjmf1979 -
    ok thanks, then hopefully it is just the drive chain that is a little looose for me......easier fix....it is a chain slapping sort of sound I was hearing
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Scootertrash's Avatar
    In the sticks
    4,638
    Did they rebuild the complete motor or just the top end?
    When it was rebuilt did they install a new chain or use the old one?
    Did they install new chain guides or use the old ones?
    See the link below for these two questions:
    Are both of the wedge shaped pieces (number 10) inside the adjuster hole? Take the adjuster out and see if there are two metal sleeves that have a wedge cut on one end. A small magnet will come in handy here
    Is the spring for the adjuster arm (number 5) located properly so it applies tension to the adjuster??
    http://www.servicehondapsn.com/fiche...1984&fveh=2805
    Feb 2009
    greentown PA
    389
    It has a new timeing chain and old guides just the top end was rebuilt . I took the left cover off and pryed the adjuster up with a screw driver its nice and quiet now. For some reason the self adjuster dosent work on its own anymore .
    84 200s almost done
    84 atc 70 project
    In the sticks
    4,638
    PAPA,
    Look at the link I posted. You need to find out if the spring (number 5 in the link above) is properly hooked on the arm (number 4 in the pic above). That spring is what pushes the adjuster arm up when you adjust the tensioner shoe. The hook of the spring should be hooked under the arm and the straight leg of the spring will rest against the case, I believe there is a lip or ledge that it rests on. The bolt that holds the arm to the case goes thru the loop of the spring.
    ETA: Did you follow the procedure in the manual for adjusting the chain? Loosen the big nut on the adjuster, not the little one, right?
    Feb 2009
    greentown PA
    389
    thanks ..... i did check out your link and everythings where it should be . and i did loosen the big adjuster.
    what i did to quiet it down was loosened the adjuster and pryed up on the adjuster with a screw driver with the left cover off then tightened adjuster nut. its nice and quiet now . :-)
    84 200s almost done
    84 atc 70 project
