Results 1 to 15 of 17
Thread: atc200 diesel oil?
    Feb 2012
    Mount Joy, Pennsylvania
    63
    atc200 diesel oil?
    Ok so I've just read in here about using the rotella 15-40 diesel oil. Does the valvoline 15-40 diesel work just the same and what do you guys think about like 20-50 synthetic motor oil?
    Feb 2012
    edmeston,ny
    10
    what are you wanting to use the oil for (what trike)and are you planning on ussing it as the transmission oil?
    Feb 2012
    63
    It's for a 1984 atc200s, not sure bout tranny isn't it all in one?
    Feb 2012
    edmeston,ny
    10
    common misconception tranny oil is for tranny only on a 2 stroke most of the oils from your fuel lubricate the crank and top end after the fuel has been burnt off
    Feb 2012
    63
    ??? The atc200s is four stroke.
    Jun 2009
    Leander TX
    2,217
    Diesel oil forumlations changed in the past few years. I used Rotella in my SV650 for years until the recent reformulations. Now, if the oil gets passed through a clutch and transmission, I use MC or ATV oil.
    Why not just use ATV or MC oil? Usually close to the diesel oil on the shelf (Valvoline makes one) and comparable cost.
    Synthetic or semi-synthetic is fine as long as it's MC specific.
    The Honda 200 engines only hold a quart anyway.
    Feb 2012
    edmeston,ny
    10
    oh ya thats right sorry got the 250 stuck in my head my bad..
    Feb 2012
    63
    Ok thanks for the input guys, how would a 20-50 no synthetic motor oil be, it's just I've read a lot about these oils being used but I don't kno how old that thread was, just want to get the best lubrication and life outta this old thing.
    Feb 2012
    63
    Here is a link to the thread I was reading
    http://www.3wheelerworld.com/showthr...o-types)/page5
    Some of the guys were talking about being scared of the adverse effects it might have on there clutch, but everyone said they had no problems, I already have some valvoline 15-40 and want to know if it will be he same as the rotella 15-40
    Feb 2012
    63
    Ok do I did some more reading and found the answers I wanted. I just went and picked up
    The rotella, that's the stuff!!! If your interested on all the info on it check out the post about Sea Foam and if you don't kno what that is read up on it as well, it's a very good aditive, for gas and oil.
    tapage is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Montrose, IA U.S.A.
    166
    so you can put deisel oil in your atc and it runs better then 10w-40?
    Feb 2012
    63
    Quote Originally Posted by tapage View Post
    I would only recommend using the rotella, as it is the only diesel oil I've researched. It is jaso certified and used and recommended by many other riders. I didn't notice any big differences in any performance but no defaults either.
    Mar 2012
    Montrose, IA U.S.A.
    166
    but does it make the engine run better then straight up 10w-40?
    Feb 2012
    63
    Well like I said I didn't notice any big difference, but it is made for wet clutch use and jaso means they ran it through the motorcycle certification. And I really like the price $17 a gallon! It's really recommended for riders who just want to get on and go, and not warm up the motor, it helps with abuse.
    4x4van's Avatar
    4x4van is offline At The Back Of The Pack Arm chair racerFirst time rider
    SoCal
    160
    OK, guys, am I missing something here? A good quality motor oil runs less than $5 quart., or less than $20 gallon. Use your head; regardless of oil type, just "getting on and going" without warming it up is abusing the engine; running diesel oil doesn't change that. If you can't take the time to warm your trike up for just a few minutes, perhaps you should be looking for a different hobby?
