Results 1 to 3 of 3
Thread: 85 vs. 86 250R Headlight Assembly
    Feb 2012
    Hartford, WI
    76
    What differences are there in the Headlight assembly on an '85 vs. an '86 ATC 250R?
    I'm looking for the whole assembly for my '85 and found a very nice original on ebay, from an '86......would I have any issues installing it?
    Thanks!
    Blossvale NY
    4,563
    I don't think there will be any issues using the '86 headlight assembly. Mounting should be the same as the front ends are the same between the 2. The headlight bulb plug may be different though, but not 100% positive..
    '85 headlight looks MUCH better IMHO and I would try and get the '85 setup if you can.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Fresno Ca
    2,695
    The 86 glass is larger, (imo looks better) but mounting and plug are the same, you just cat miss and match plastic and glass housing bulb is even the same
