Here it is. I've done a ton of work to it. goods=new stearing stem bearings, new front and rear wheel bearings, new all balls swingarm bearing kit, new top end gasket kit, new barnett clutch kit, new valves, new motion pro twist throttle and cable, new rear tires, new carb rebuild kit, front master cylinder rebuilt, newer brake pads, new oil pump, new timing and oil pump chains, all lights work, have parts to rebuild the original parking brake(have billet block off on it rite now), have box of original parts as well, the list goes on i forget some im sure. Bads=rear plastics are, seat cover is
(seat is in restorable condition though), front fender is original and has scrathes, no cracks(also still has the brake line clip on it), headlight plastic has couple of cracks(stitched but now has headlight cage) motor has a couple helicoils put in it that push out a little oil(very little) these are on the clutch side of the motor, needs air filter, a few bolts have broken on me since this bike was in disrepair when i got it, i have the head pipe gaurd but it kept rattling of because i dont have the gasket that goes between the head pipe and tail pipe, im sure there are a few more things. Any feedback on what you guys think its worth would be great, I'm in some desperate need of some cash rite now and i may need to part with it. I do not wish to get rid of this trike, but i may not have a choice. thanks for any advice!!
