Results 1 to 15 of 20
Thread: 1982 honda restoration NOW WITH PICTURES!
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    well here is what i got , a 1982 honda 110 its pretty much all original , the tires are in vgc, breaks work alright , motor runs with no issues but leaks oil like crazy. i ordered new front wheel bearings , steering stem bearings , recoil handle , light bulbs for front and rear. i need to still locate a front fender , seat pan and foam and cover, exhuast, rear left mud flap. i plan on rebuilding the motor with new gaskets, oversized piston and rings . i also plan on sand blasting everything and powder coating, i need some help with motor clean up and prep for painting. also the chain that was on it did not have a master link on it , it was a o-ring chain....i had to cut it off. ill post all the pictures i have of the stuff i already did tonight.
    thanks again for the help and support on my FIRST restoration.
    jake roth
    May 2011
    rochester ny
    288
    any one have ideas for exhausts?
    maybe some light mods?
    Oct 2007
    new york
    811
    seat foam i have been saving from the 110 i had .guess i could part with it since i sold most of the other parts . Click image for larger version.
ID:	142188Click image for larger version.
    May 2011
    rochester ny
    288
    what are you looking to get for it , do you have any other parts? thanks again!
    May 2011
    rochester ny
    288
    orderd alot of parts tonight , bearings, bulbs new breaks
    May 2011
    rochester ny
    288
    parts came in
    got front all balls bearings , bulbs , i also removed the rear axle housing, its in great shape. i have a question there is bendable tabs on the frame with rubber gromets on them , can i powdercoat over them or grind them off?
    also in my manual it says to put a grease fitting on the axle housing.... any oneever do that?
    ill post more pictures tonight but its coming along great , for myfirst restoration.
    thanks for suport jake
    May 2011
    rochester ny
    288
    can anyone post pictures of the exahust set ups there running and some info on them, i wana try to get as much power and fun out of the 110 with out breaking the bank.
    May 2011
    rochester ny
    288
    anyone?got any pics or ideas
    May 2011
    rochester ny
    288
    All parts except frame and axle are sand blasted its starting to come together nicely
    May 2011
    rochester ny
    288
    pictures and progress
ID:	142441Click image for larger version.
ID:	142440Click image for larger version.
ID:	142442Click image for larger version.
ID:	142443Click image for larger version.
ID:	142444Click image for larger version.
ID:	142445Click image for larger version.
ID:	142446 heres alot of pictures of what it looks like
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Really? just ONE reply?
    Looking good, hope it all goes well !!
    NEPA
    7,051
    Very nice ! For engine clean up,,purple degreaser,,castrol,or the auto parts store imitators are even better. Let it soak 5 minutes,blast it with a steam jenny. Or good pressure washer. Then you're ready to blast,scrub,sand polish or just plain reinstall it depending on how fancy you're gonna get. The tabs on the frame can be painted or PC'd/ No problem. You're doing a great job. Can't wait till it all comes together! Exhaust? There is a place that makes damn near every exhaust there is,but I don't have a clue what their name is,or where to start searching.
    Southern MN
    1,875
    Denniskirk.com has the DG system, and its about 130, thats the only system I have found during a quick look. I know they made a lot of different brands back in the day, like jardine, super trapp, bassani, cobra, etc. I would check ebay from time to time to find these. Keep in mind the exhaust will make it significantly louder than it is now, but will flow much better. The bike looks great so far, keep up the good work!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    May 2011
    rochester ny
    288
    well i have the frame all cleaned up and are starting to coat itt tonight, can some one post pictures of the exhaust systems there using and pros and cons about them>?
    May 2011
    rochester ny
    288
    i wana get chrome or different color bolts for the motor is tht a thing i should do or just leave it as is?
