but it kick starts and everything works.
I can't even find the fuses.
Recent dental work makes it impossible to even bend over to look.
On the sx, the fuse is by the battery.
Thanks
ok, so the main fuse of the 250sx is real obvious by the battery and the 250es
is a flat piece of metal hiding in a rectangular rubber 2 piece case that holds a black box by the solenoid and is best replaced with a fuse that is more commonly avail?
I wonder why they designed them that way?
These are pix I found using the search key.
Guess I'll look for some sort of fuse holder and splice it in.
