Thread: Oil pump, Test?!?!?
    Feb 2012
    Mount Joy, Pennsylvania
    63
    Oil pump, Test?!?!?
    Is there any way to test that the oil pump is fully working properly? I read a thread about removing the casing and cleaning around it because it is something that is rarely done and should be. Haven't done that yet but plan to, was wondering if there is a good way to make sure the oil pump is good while it's all apart.
    Feb 2012
    63
    Oh sorry 1984 atc200s
    May 2009
    S.E. Michigan
    1,251
    The part that needs to be cleaned is the centrifugal filter (or oil filter rotor per the service manual), which isn't actually part of the oil pump. THe centrifugal filter is a weird thing, but basically oil is pumped through this and gets spun by the motor. THe crud sling to the outside surface, and the good oil flows out the center. I cleaned mine once and noticed a buildup of some sludge, but nothing too nasty. It requires you to get into the crankcase (right side on the 200ES big red, I think the 200S is common). If you are in there for any other reason, it would be worthwhile checking.
    As for testing your oil pump, I'm not sure how you'd do it. If you really want to know, I think you need to inspect it by disassembling it and checking the clearances with feeler gauges. But, this would require more teardown of the parts... if you suspect a problem, go for it, but I'd leave it alone unless you really want to play.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2011
    eden,ny
    3,481
    I know the yamahas have a bolt on the head that you pull out to check oil pressure. not sure about the hondas
    May 2009
    S.E. Michigan
    1,251
    Quote Originally Posted by ben6626 View Post
    On the 200 motors (S, ES, M) I don't think there are any external access ports to the pressurized oil system... and if there was, I'm not sure what an acceptable pressure would be.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
