Results 1 to 13 of 13
Thread: keihin pwk 38mm ?
    Tucson
    1,652
    keihin pwk 38mm ?
    Anybody ever seen this on the pwk carbs?? has me puzzled I have searched up and down trying too find a answer as too what this is!!!what seams too be a rubber oring stuffed and broken up between the part thats not removable from the factory!!! Anyone have a Idea?Click image for larger version.
ID:	142341Click image for larger version.
    Tucson
    1,652
    Tucson
    1,652
    Didn't think anybody would know!!!! I never seen nothing like it myself!!!!!!
    Ontario, Canada
    457
    If you take the bowl off you can remove the assembly, you'll need a new o ring!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Tucson
    1,652
    You cant remove the assembly, the whole part the main jet sets in is put on by the factory with a special type of fasteners!! Thats what dont make no since.. there are no orings inside the float area!!! This had to be put in by the factory, what I would really like too know is where you would send it too for factory service? Sudco? Or is it just junk?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    thats a new one on me
    Tucson
    1,652
    Your not kidding billy, I have heard nothing good about sudco!! Mybe I will at least call them and see what advice they might ne able too give me on this situation! The carb was new before I tore the motor down for a rebuild, then cleaned the carb and this what I found..
    Ontario, Canada
    457
    Seems to me it's just a security torx
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    Oregon
    2,471
    I would send it off to Keihin, have them figure it out. Let us know what they say.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    Tucson
    1,652
    Quote Originally Posted by ceaserthethird View Post
    Ceaser, thats what I would like too do but I would rather go through a distributor!!! have any clue which distributor would be good?
    Tucson
    1,652
    Quote Originally Posted by TtownJoeShow View Post
    It is a security torx and there is a gasket under that piece that you can not buy not too mention the rubber oring deal that you see!!
    Ontario, Canada
    457
    Ah! Well that's a bummer!! Who ever you got it from, I'd let them know and ask how no one noticed it!! Not to mention how long it might have kept you from riding.
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    Tucson
    1,652
    WELL,, guess my next question is,, Its new carb time! Anybody think the air striker is better then the standard 38pwk??
