Results 1 to 14 of 14
Thread: Largestr tires that will fit a 1985 Honda 250r atc/ 3 wheeler
    Mar 2012
    searcy
    87
    Does anyone know what is the tallest rear tires currently available that will fit on the rear rims of a stock 1985 honda atc 250r and also on the front rim ?
    Dec 2009
    BFE
    1,202
    Prolly the tallest tire your going to find that will fit your rim size is a 25" tall, but why would you want to put that tall of a tire on a 250r?
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Mar 2012
    searcy
    87
    the 22 " tall tires a bit to low profile for riding in my area { woods , trails, with streams, logs to ride over, etc...}
    so I was looking to get a bit more ground clearance for local riding. I dont race this 250r and I dont have the money to purchase another atv that is a 4 stroke with tall tires.
    Could you give me a link to a set of tires that are 25 " tall, that would fit my 1985 rear / front rims ?
    Dec 2009
    BFE
    1,202
    Just search on denniskirk.com you can do a search for tires by rim size. A 85 250r is a pretty desirable machine you could easily sell or trade it for a nice utility machine like a 250 big red that would be better suited for you riding enviroment. The 250r stock clutch wasn't designed to handle that big and heavy of a tire.
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Mar 2012
    searcy
    87
    so you think I would destroy the clutch, if I went with 24-25 " tall rear tires..even though im not racing this 250r ?
    what if I went with taller tires, but less wide/thinner on the rear ?
    I like the 250r, and really dont want to sell it...i just want to make it more suited for my local riding conditions..which is trail riding thru streams, and wooded areas.
    Dec 2009
    BFE
    1,202
    I dont think it would destroy the clutch but it would cause it to wear out faster then just riding on stock sized tires. What kind of tires do you have on it now? Maybe you could just get some more agressive tires for the rear.
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Mar 2012
    searcy
    87
    the tread isnt the problem..its the low ground clearance..with the 22" stock tires on the rear...there are alot of streams we ride thru..and it would be nice to at least be able to use a 25" tall rear tire..even if it is less wide..
    NC
    907
    If you go with the taller tires - to save your clutch, simply regear with different sprockets. Smaller on the front sprocket, bigger on the rear.
    NC
    907
    Also the stock tire size for the 85 250r is 20".
    Mar 2012
    searcy
    87
    I appreciate all the replys..
    so can anyone recomeend a 24" or 25" tire that will work on my rear rims...along with telling me what size front sprocket I should switch to, so I dont burn the clutch up
    this is for a 85 atc 250r
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    and with a 25" tire your fenders will be gone in the first big bump... there is not enough room for a 25.....
    Mar 2012
    searcy
    87
    my fenders are already gone :}
    they were cracked badly, so we just cut em down
    Dec 2009
    BFE
    1,202
    I put 28" Vampire EDL's on my 350x just as a joke. I rode it around the yards once that was it. They was about to rub the fenders with just me setting on it. But If you have no fenders to rub then go for it. Sounds like big tires it what you have your mind set on.Click image for larger version.
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    NC
    907
    There are alot of sites out there for tires, here is one:
    http://www.smalltires.com/categories/atv-tires.cfm
    Gearing guide copied from an old Dirtwheels mag
