Results 1 to 15 of 16
Thread: cobra exhaust for ATC110
    atc110 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Milwaukee, WI
    244
    Hey there's a cobra exhaust system for a 110 on ebay and I was wondering if anyone has a cobra on a 110, or any other wheelers and what they think of it
    1982 Honda ATC 250R (for sale $600)
    1985 Honda ATC200X parts (for sale)
    1985 Honda ATC 110
    Fresno Ca
    2,695
    its a mini atc and with that exhaust it gives it a bigboy sound, basicaly like any exhaust for a mini its all for sound.
    Dec 2002
    salem, nh
    1,339
    it helped a little on my resto, but it's garbage. it rusts in like 2 weeks. u should just buy my whole 110 with the pipe on it for $350 :-P
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    1,736
    so cobra or DG exhaust, whats better for my atc110?
    pa
    31
    The Cobra sounds pretty mean on 110, I don't see any problems with it and i think it gives it a little more power.
    1,736
    actually i think i have my mind set on the DG, my friends cobra on his lt230 rusted out fast, and DG just seems like a higher quality, i have owned them in the past and they just seem better built, unless anyone has ever had a DG on a 110 and they suck (???) and know the cobra is better (???) im gonna get the DG.
    anyone have any experience?
    PA
    3,515
    I know if i had a choice between a cobra and a dg I'd pick the cobra every time.
    I have run the same cobra pipe for years on my built 110 and with a coat or high temp paint it still looks new.
    I have also run DG pipes and currently have one on my RX...... I'd take a cobra over it.
    WWW.HREATV.COM
    Oct 2007
    Minneapolis mn
    4,067
    IMO Cobra pipes are a bunch of junk.... Loud Junk...
    1,736
    what about a Basanni pipe, i know they made them for 110s at some point, does Basanni still make them? and what about these compared to DG and Cobra? i have 0 experience with Basanni. any comments about them?
    PA
    3,515
    Unless you have a built up motor it really dont matter what pipe you throw on a 90 or 110.
    Even then other then sound I doubt you'll feel anything between them. Now, if you throw one on a stock motor it should run worse. My daughters 90 ran like crap with the cobra but my built 110 loves it.
    WWW.HREATV.COM
    Nov 2008
    ontario
    1,055
    i would stay stock if possible, do you want loud? do you want to have to rejet your bike? the paint burns off the cobra within 10 minutes its bare metal
    proud owner of a trx300ex quad and an 85 atc 70
    1,736
    im actually throwing in a high comp piston and a longer duration cam, im aware of needing good back pressure on the stock engine, but like i said im going a different route, im actually gonna post a thread on a piston, got some questions
    oh and daniel, im looking for performance, loud or not. and somthing that will last, i have no problem painting the pipe after every ride, lol
    Hopkins, Michigan
    What exhaust did you wind up with? I just ordered a Cobra and would up with the wrong header pipe. Going to return it. Did you get something else?
    Jan 2011
    NW,Ohio
    49
    I have both a DG and a Cobra exhaust on my 79-81 ATC110's I like them both, I believe if you rejet them properly they work better than stock. Mine do. I also ported my heads and open the exhaust port up to the size of the ID size of the header, I have the cam DRATV sells with more duration. and I have a .50 over pistons, I been wanting to try the +4mm over piston with the 10to1 compression ratio. I have the piston I need to get my extra cylinder bored out. There 110's there fun to squeak every bit of power out of them and keep them reliable.
    1,736
    I really like my DG i got. not to loud, works good.
