Hey All,
Mike at HRE is making a custom swingarm for my 350x project and he is in need of a dimension. Hopefully someone here can help with this as I am in China for two weeks for work. It is kind of a hard dimension to explain so I created a diagrahm to help. I need two dimensions actually. The first is the length from the outside surface of the left pivot collar on the swingarm to the centerline of the rear sprocket. The second dimension is basically the same dimension, just without the collar installed. If anybody can assist with these, it would be greatly appreciated. These dimensions are needed to set the carrier location on the swingarm.
Thanks,
xrider
