25 dollar trike and parts from the vortex (tin shed in the back yard) now if I can just get it to start.![]()
Holeshots. niiiice haha
1987 Honda FatCat -Gripper seat, +1 front sprocket
1987 Honda TRX250x- Suppertrapp IDS2, +1 front sprocket, DuraBlue axle, HotCams, 10:1 piston, +2 widened
1983 Honda 200e BigRed-Has a ViseGrip for a shifter, 'nuff said.
1971 Honda Trail 90- Original Everything
Previous Rides:
1981 Suzuki TS100
1990 KTM 300exc
looks good. did you pull the top end to see what was in side?
Almost expecteds for 25 bucks!!
O haven't pulled it apart yet, wasn't froze and has great compression so figured I would change the oil and try it out. Haha! Yeah none of the 50lbs tires on this one. I have a mountain of those already! Need to check timing and valve clearance won't start yet.
check spark!i bet the stator connections are rusted or the ignitor is bad. very common for them.
Hell, I say weld an olf john deer seat pan to it and ride it.![]()
________________
https://www.mikesatvfix.com
Some of us drive corvettes (shortline10) others roll in chevettes...
It's alive!!!! Set the timing, ground the points, pulled the cord and off I went. Total investment... Priceless.
