Results 1 to 15 of 17
Thread: SHHhh wife doesn't know I got one yet. ;)
    Mar 2007
    Texas
    5,045
    ok over the weekend I locked down a 85 350x. I have been chasing good deals for a very long time, well my time finally came!!!! origional owner was the grand dad, and the dad then the son. The son (closer to my age) decided he did not want to fix the bike (not running due to fuel left in system and it varnished up the tank and carb is my diagnosis when checkign it out). Anyway long story short, I am the 2nd owner and will get title!!! also the bike has NEVER EVER bad any major work at all. the top end has never been appart nd it has never had a clutch replacement! Here's the kicker, mostly garage kept, so the plastics are near mint!!!!!!!! 2 small cracks on the front fender rears are nearly spotless! anyway, They are holding it for me till I get back from movign to Cali from Texas and then i'll have it.
    Before we get started, I'm not restoring this to show room. it's getting a "refresher" for riding and using for fun.
    so here's my questions:
    1. front forks are shot. i can push down 1 handed and nearly bottom them out. Recommendations to resovle this? (upgrade to 250r forks? rebuild these?)but the rear shock is mint and works flawless!!!!!!
    2. Rear bearing carrier is ok, but the bearings have some play so time to replace them. should I get a whole new carrier or just replace the bearings? (my first 350x so if replace carrier what i need is the name of some good stuff) (Is the 85 and 86 the same carrier? seen some nice ones on line but they mention only 86 not 85)
    3. front brake line has the origional clear sheeth still on it. it's cracking off and messed up, but the rubber is mint under neith. my guy says to replace with SS but should I?
    4. should i replace the front bearings too while i do the rears. sounds dumb, but i usually don't replace them unless they need them. Thoughts?
    5. swing arm bearings feel solid no play, but should I look to replace them anyway to ensure nothing is rusted together and what not cause on the 200x, I always replace no mater what for a peice of mind. but is the 350x more stable?
    6. fuel tank is original fairly clean has a coupel of dents. it is fixable. should I just fix it or get a clark?
    being my first 350x i have owned, (worked on a few but never owned one myself and msot of the work was engine related) i want to make sure it stays trail capable for many more years.
    ________________
    https://www.mikesatvfix.com
    Oct 2007
    Minneapolis mn
    4,067
    Hope your couch is comfortable.... Wife is gonna be pissed!!
    Nov 2010
    Oshawa, On, Canada
    2,123
    1. I would recommend rebuilding the 350x forks! Its a fairly easy job, if you have never done it, i have a very detailed write-up about how to do them. ( on the other computer, of course.)
    2. Just replace the bearings with a well known, proven brand. OEM is best, but i've had goodluck with all-balls bearings.
    3. Keep the OEM brakeline. It will be fine for years to come! Replace when necessary.
    4. Hold your knees on the front tire, and shake the bars with your hand. If there is any play, replace! If not, no need to do them just yet.
    5. The pivot bearings are something i would recommend doing regardless, they tend to seize, so it is better to do them to make sure that they will come apart next time too!
    6. If the tank only has a few dents, I would fix it. But, if you really don't want to fix it, you could go to a Clarke tank. The only problem with them is that it will not stay white for very long if you leave gas in the tank when it sits.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    OHIO
    2,857
    pics pics!!!!
    Mar 2007
    Texas
    5,045
    Jason125m, Thanks a ton! grate info.
    Don't have photos yet as I only went to look at it yesterday and purchased it. (hold deposit and will give rest when I return) Sorry guys, I didn't think to take some photos.
    Sorry lonts happennign in my life so it's hard to remember to do everything. I'm jsut very lucky to have found this bike. i'm gonna really take are of it and jsut enjoy the hell outta it!
    ________________
    Mar 2007
    Texas
    5,045
    naw thrope, it was either $1000-$1200 into a 350x (with parts needed to get it working good) or a new yami YZF450 ($7k) so i think she'll settle.
    ________________
    London, Ontario, Canada
    1,059
    I'm with Jason as well
    Rebuild the front forks, New OEM seals and wipers, good fork oil, if the springs are sagging a bit some plastic spacers to take up some slack. I personally would replace rear axle, front wheel and swingarm bearings and seals with new. That way you absolutely know you are in good shape for years to come. Tank is cosmetic, It won't make it run better or last longer and can be replaced or fixed when you decide to spruce it up.
    While you have it apart for bearings is a perfect time to inspect /replace / lube all the other wear spots the previous owners may have neglected, chains,sprockets,brake pads, caliper pins etc.etc.
    You'll know the machine is capable and up to whatever you put it thru and not have to worry about that "one item" you didn't look at.
    Enjoy the machine and the doghouse.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    May 2009
    S.E. Michigan
    1,251
    I'm with the other guys: try to rebuild the original parts as much as possible. I'd do the front wheel bearings too (like the other said above). I also second the opinion on checking out other spots, even if you aren't replacing anything. Case in point are the brake calipers. The caliper slide pins really should be greased so keep them from seizing up. Same with the rear pivot bolt. Even if you aren't replacing the swingarm pivot bearings, it would be a good idea to remove it, and coat it with anti-sieze, then reinstall.
    Also, the top mount bolt for the rear shock will benefit from the high moly content Honda grease (60% moly).
    I'm not a fan of the aftermarket plastic gas tanks. One of the drawbacks of the plastic is that you can't keep stickers on them (the gas fumes permeate the plastic and mess up the adhesion).
    You gotta post pics once you get it!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    It's gonna be a long haul; But worth doing. If there is any play, replace the bearing.
    And yes, clean those forks spotless and install new OEM seals.
    If the tank just has a dent, pull it out. I'm very pleased with the 2 IMS tanks I run........
    Just tighten that beyatch up!!!!!!!!!!!!!
    Apr 2009
    Parker, CO
    607
    I might take off the rear fender if they are super nice. Get a cheap cracked one from ebay or some such. Then sell the OEMs. Sad to bust up nice OEM plastic. Might as well sell it to someone for their garage queen. Good luck with the new trike.
    Visalia, CA
    720
    86 and 85 carriers are not the same. If the slots in the carrier aren't all messed up from dummy's taking a punch and to it, keep it and just get some new bearings and seals. Get OEM if possible.
    "Your 4 wheeler must be fast because you were haulin' ass....UNTIL I passed you on 3 wheels"
    RIDE RED......OR RIDE HOME
    TRIKES ARE NOT DANGEROUS......IDIOTS ARE!
    RIP
    NOS_350X is the most bad-ass person in the world
    Hampton, Virginia, C.S.A.
    2,664
    Quote Originally Posted by Shorty View Post
    true but i have a 86 carrier in my 85 ..the aftermaket sprocket someone put on before i got the bike was flat on one side and countersunk on the other side..i went to the hardware store and found me some bolts with small heads on them and it worked great...so the 86 does work in the 85 you just have to find a sprocket with countersunk holes...and either find bolts with small enough heads to clear it...or buy the 86 countersunk bolts
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mar 2007
    Texas
    5,045
    yea, i'm thinking about what threewheelin feelin said. (i read about the bolts and using the 86 sprocket. i'll inspect the 85 sprocket if it's worn, then 86 setup it is, if not then I'll jsut do bearings.)
    ok forks, i'll redo as recommended and do swing and front bearings too. good point on the brakes.i will also probebly repalce the steering stem bearings ith a cone kit. smoother, stronger and easier to deal with.
    Thanks for the advice guys, as mentioned i've worked on them, but not done them for myself and msot work was motor work, so i just want to make sure everything I do is on par with correct. and i know i'll ge pics soon. Actually i want to keep the origional plastics, but I will get a set of crappy ebay ones to keep these nice ones for anotehr time when I restore the bike. one day i may do a ground up jsut to do it, but now now, it's for fun.
    ________________
    Mar 2007
    Texas
    5,045
    ok boys, I jsut picked the 350x up about 30 min ago. i have not gotten pics yet, but will post some tomorrow (if the wife don't gut me like a fish first).
    it's in decent shape for being all origional and all. i even got the title signed over to me and everything! yea i got it from the origional owner!!!!
    ________________
    glendive, montana
    1,822
    with your thought on the tank I myself would buy a clark replacement, and keep the original stored, after pulling the dent first lol. I look at it as if it is going to be used and used well keep what's nice nice and get replacement while you still can so when you need it you still have the oem tank.
