Quadrunner parts on a Kingquad?
On my 1993 Suzuki king quad 250 ( ltf4wdx) I need a new rear right swing arm, hub, brake drum, brake drum cover, and a backing plate would save me the trouble of drilling out the screws on mine. I was wondering if anyone knew about the compatibility of the rear right swing arm, and everything that bolts up to it, from a quad runner or king quad 300 from those years. While at well over a grand OEM, Getting parts off the exact same model type as mine is going to run probably 300 maybe 400. Quad runner parts are dirt cheap however and would cost about 1-200 for everything. The backing plate looked like it wouldn't work but a lot of the other parts did. Thanks in advance.
check the part numbers on each, if they are the same, the numbers will be the same as well
//ArrowChat Integreation Code
