Results 1 to 10 of 10
Thread: 1986 Big Red Quits running
    Mar 2012
    Iowa
    5
    Hi, I just picked up a 1986 Big Red. I went through the carb, cleaned the gas tank and air cleaner. Put a new battery in it and it started right up! I took it out for a ride and got down the road and it quit. After 5 min I was able to start it again and return home. Every time I get it out it starts right up and get so far then it quits... Any suggestions on what to look for? It just kinda putters out and wont start again and backfires until it will start again.
    Any suggestions are helpful.
    ThanksClick image for larger version.
    Mar 2012
    searcy
    87
    if its backfiring, thats often a sign of not getting enough gas...but could also be a electrical problem...bad coil / stator, etc ?
    Mar 2012
    Jamesport
    40
    most of the time when that is happening it's a bad coil, the coil heats up and the motor breaks up or quits, I would start there.
    Michigan UP
    1,005
    Is the vent on the gas cap working properly?
    fingerlakesny
    2,834
    ya, what briano said, ride it and if it quits pull the cap off and see if it starts right up.. i had that problem...
    Mar 2008
    EastGreenbush, newyork
    3,494
    X3 on the gas cap vent!! they are notorious for going bad!! most of the time when it first starts to cut out, pop the cap, and it will rev right back up!! there is an easy fix for this by just drilling a small hole in the underside of the cap! maybe try a search on here to see if you can find a pic of where to drill the hole!
    Mar 2012
    Iowa
    5
    Thanks for the things to try and look for, I will see what I can do about it tomorrow. I would also like to mention that the 3 wheeler is for sale if anyone is interested.
    cwc is offline New to the board Arm chair racerNew to the board
    Feb 2012
    Middle Georgia
    47
    Quote Originally Posted by johnston repair View Post
    thanks for the things to try and look for, i will see what i can do about it tomorrow. I would also like to mention that the 3 wheeler is for sale if anyone is interested.
    how much $$
    Mar 2012
    Iowa
    5
    I am thinking around $800 but am open to offers.
    Michigan UP
    1,005
    If it is the cap, I just had 2 bad ones on my 70s. I soaked one of them in vinegar for a couple days and it seems to work now, that will eat all of the rust out.
