Results 1 to 11 of 11
Thread: 185s Decompression Cable
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Ok my cable works just fine I would just like to know if anybody knows what the end that isn't attached to the head is supposed to go to? Is it somewhere near the pull start? Mine wasn't hooked up when i bought it.
    Apr 2006
    SE CA Dez in the sandbox
    900
    There should be a rubber grommet near the Pull Start which the cable end passes through and attaches to the pull start drum.
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Do you know of any pictures i can see this in?
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    WNY
    124
    Quote Originally Posted by ZacH_GrifF View Post
    Just tryin' to help..
    Feb 2012
    washington
    83
    you might have a different year pull start that doesnt have part number 20 or 15 in diagram above or a top hole.
    Dec 2010
    washington state
    681
    can be a pain getting together, good luck
    GOT MUD?:
    Feb 2012
    washington
    83
    hey, stick to your 350x m
    Dec 2010
    washington state
    681
    hey ,i like to waste time in between polishing parts!!
    GOT MUD?:
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Quote Originally Posted by vonlindheim View Post
    i have the 83 case with hole in the top so i guess im missing the part it hooks to?
    3. 85 200m
    Feb 2012
    washington
    83
    just take the cable off. plug up the top hole of the pull starter with tape ( stops dirt from getting in ) and disconnect the cable from the head. you can leave the lever on. it wont activate. most 185sand 200s are easy to pull start and don't need the compression release function. its supposed to make starting easier, but you be the judge
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Yea I decided to just take it off and just lift the lever till it stays up by itself everytime I crank it.
    3. 85 200m
